have tryed to get epg with crossepg but when i go to configuration i get the driver must be mounted inrw if you cant see your device here probably is mounted as read only or autofs handle it only in read mode in case mount it manually and try again what im i doing wrong how to fix thank yiou
help crossepg
i had a problem when first installing crossepg, my image could see hard drive but crossepg wouldnt, does your crossepg see the drive or does it say something on the lines its not mounted or not in rw mode.
i had to remove hard drive because box wouldnt format it properly and formatted it with gparted in the end, worked a treat after setting up crossepg after that
woops.... didnt read your thread properly
heres a tip, remove drive and format it ext3 and all will be fine
