how do i change language settings in gemini 4 .2 image
  • chavslav
    • 99
    reflashed box, had gemini 4.2 image put on, ages on screen with just gp, went to pc to start internet, returned and the language is now in french, how do i change back to english, thanks
    1 metre dish,tm 5400ci super,tm 1500ci super,dreambox500s(currently a harsh learning curve)..
  • smoggie
    • 863
    hi m8,
    try a reflash and use the pli jade image, well recommended. If you dont want to reflash, go into expert set up, do you have an option similar to user interface settings?? it will be in there
    • chavslav
      • 99
      Originally posted by smoggie
      hi m8,
      sorted got english back thanks, can't find cccam.config in dcc any thoughts???
      • mdt
        • 3034
        just ftp your config file in var/ect and then restart the cam and it should clear. dreamboxs are fun arent they!! regards mdt
