football - recommended channels?
  • ratski
    • Sep 2011
    • 11
    gonna set up my dreambox using my old sly dish, however i only really need it for the football nothing else
    is there a recommended setting for the dish (non motorised) i can leave it on to just pick up the best premiership football stuff, ideally without cs?
    Not gonna happen unless you've got a card or a sub.
    • andy91
      • 3583
      Your dish will be pointing at 28.2 Astra SkyUK so you will only be able to pick up fta and Sky with a card.
      All the football you are reading about are on different sats.
      Andy.
      • ratski
        • Sep 2011
        • 11
        so i cant change the angle of the sat to a service that shows the footy? the sky dish as you know is quite small anyway so pretty useless i suppose
        i will prob keep it to 28.2 then and set up my first stuff from there,
        been reading jade is the best image to start with? shall i stick to that?
        just need a setup guide now but usually ok with techie stuff so hopefully wont need to bother you much
        • andy91
          • 3583
          European dish needs to be 80cm,you probably could pick up Hotbird with the mini dish but quality could be affected and the further north you live they say get a bigger dish.
          Dishes are not alot of money you could put up a second dish for under 30 quid if you did it yourself.
          80cm Satellite Dish Hi-Gain & Pole Mount Fittings | eBay
          Most recommend Pli and its my recommended choice.
          Setting up is relatively easy.
          Andy.
          • ratski
            • Sep 2011
            • 11
            so if i upgrade the dish, i can setup for euro sat and pick up say hotbird with something like al jazeera sports an watch football? will this be possible without cs?
            • andy91
              • 3583
              Not certain if Al Jazeera are showing that much epl footy this year if someone can confirm??
              You will only get the likes of Al Jazeera,Tring Viasat with a card or a sub.
              We cant say to much about c/s on here,
              Andy.
              • ratski
                • Sep 2011
                • 11
                yeah no cs talk i understand
                but either way, if i sort out hotbird for al jazeera i will still need a card and sub?
                cheers for the help
                • andy91
                  • 3583
                  cheers for the help
                  From little footy ive seen this year when i checked Al Jazeera they wernt showing any Premier League Footy.
                  Hopefully someone else can confirm this?
                  Check this website it shows what footy and sats footy is on.
                  *** L.J.s LIVE Sport on Satellite TV. Live Soccer on TV. Live Football on Saetllite TV.
                  Andy.
                  • ratski
                    • Sep 2011
                    • 11
                    thanks for all the help andy
                    can you just clear one thing up
                    if i had a motorised dish (large enough!) and i pick up the euro channels are these fta or need a sub?
                    i kind of understand the cs route for sky uk but does this apply to all the euro channels as well?
                    just trying to get my head round all this and choose the best route to go down
                    • andy91
                      • 3583
                      1 Metre set up completely supplied and fitted about 170 quid unless you have a go yourself.
                      Regarding the channels either a card or a sub mate.
                      Most on here probably have a sub or share a card but thats as much as we can say on the matter
                      Will send you a pm
                      Andy.
