ecmwhitelist for sly
  • davvo
    • Apr 2009
    • 666
    oscam server
    [reader]
    ecmwhitelist = 0963:3E,4E,42,44,45,47,6A,6B,6F,62,68,69,7C,7D,7E,72,73,77,79,80,8B
  • satsmo
    • 6397
    For oscam post build 5137 I presume davvo? I had a problem with LEN sizes on previous builds as it wasn't implemented.
    • davvo
      • Apr 2009
      • 666
      @satsmo
      for
      • southpaw
        • 2233
        i have googled this topic and come across this below , Not my work btw , un ashamedly cut+pasted from elsewhere
        Oscam - Protect your sly uk card
        An interesting new feature available in oscam post build 5137 is "ecm whitelist"
        Let me explain :-
        Theories suggest that those who have had there cards turned off by sly for c/s was due to a special ecm request to the card from an infiltrated network.
        In simple terms - a user requests a special ecm which only sly/n$s know which then answers back with either a boxid or serial number to the card. This special ecm would have a different LEN to the normal size ecm.
        So oscam developers added a new feature which goes into oscam.server file . The line of text goes to your appropriate reader section and looks like so : -
        ecmwhitelist = 0963@000000:3E,4E,7D,7E,45,47,62, 68,69,6A,6B,6F,72 ,79
        The official info from oscam is as follows : -
        ecmwhitelist
        parameter is optional
        NEW svn 5137:04/30/2011
        ecmwhitelist = [CAID[@ident]:]lenght[,lengtht]...[;[CAID[@ident]:]lenght[,lengtht]...]...
        define valid ECM length in hex and ident for physical reader
        example
        ecmwhitelist = 10,20,30,0a,0b,0c
        = 0100:10,20;0200@12345:0a,4b
        [blank] = none (default) and ident 000000
        In normal operation mode this parameter is not required!
