How to add channel logo
  • sony007
    • Sep 2011
    • 249
    How do I add the logos for the channels? so when I press OK on the remote it doesn't show 4Reackt.com in the box in the left hand corner but BBC1 or SLY SPORTS.
  • alom5
    • 1648
    you will need to download picons. i don't know how it works on the 4react image....i had issues getting it working.
    • sony007
      • Sep 2011
      • 249
      Managed to do it, cheers m8
      • SGTFlipFlop
        • Sep 2009
        • 1002
        Best to share how you did it mate incase others get stuck and they can get the answer from here
        • sony007
          • Sep 2011
          • 249
          Yeah I will do once I get back home tonight, but it is a picon that you need to install. I can't remember how I got there without being infront of my Dreambox but it's only about 4 to 5 steps, will write the steps here tonight.
          • garry1312
            • Oct 2010
            • 2178
            Easy they can be downloaded from Tspanel, only gives you option for flash. So can be a bit much if you are wanting picons for multi sat, but just the one sat and you are fine.
            Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
            • sony007
              • Sep 2011
              • 249
              Menu > Plugins > TSpanel > Addons > TunisiaSat Dreambox Addons or any of the others that may be in your list > Picons > and then your satellite.
              I hope this helps.
              • lemonpie
                • 35
                i've manage to download them all on to my hdd but can't work out how to run them from there?
                i'm using newnigma2 v3.2.2 on the dm800se.
                can anyone help please? thanks
                • alom5
                  • 1648
                  newnigma2 services - osd settings -change the location of the picons to where they are stored and the lcd display type to picons only. restart...job done.
                  • lemonpie
                    • 35
                    cool, apart from they are just plain writing and not in colour, the ones in the folder are in colour, like little logos, have i missed something?
                    • alom5
                      • 1648
                      are they in colour on the infobar? what folder you got the picons you want displayed?
                      • lemonpie
                        • 35
                        no they are not showing up on the info bar at all, at the right hand side below the channel number is just a rectangle split into 5?
                        • lemonpie
                          • 35
                          media/hdd/picons
                          • alom5
                            • 1648
                            needs to be in /piconhd rename folder and it will work.
                            here are the picons i use http://www.digital-kaos.co.uk/forums...97/index8.html
                            • lemonpie
                              • 35
                              there is another folder called usr with some sub folders.
