i have 2 dreamboxes connected to a dual lnb ,however when connected if the dish is positioned so i get 98%sig on the downstairs box ,the upstairs box gets no signal and vice versa,any ideas how this can be rectified so i can have both working at same time CHEERS
problem running 2 dreamboxes
Tags: None
alotmentman
looks like lnb fault ,mate disconnect one see if runs ok /vice versa ////get new one should be rate thenComment
not with the same sea-lineplease press the little red THANKS tab
if I helped
if not press the green tab to tell me to f**Koff
Dont suppose both boxes are sharing the same ip address?
This would cause the premium channels not to work when both on at the same time.
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
