cool tv missing half of tv channel
  • lemonpie
    • 35
    hi,
    i wonder if anyone else has the same problem as me with coolmans tv guide, the tv channels listing on the left hand side are cut in half, i've messed around with the settings but don't seem to of got anywhere.
    i saw in another thread where they looked like they were in full, i'm using newnigma 84a by the way, but what ever image i've used the above problem is still there.
  • LraiZer
    • 126
    have you tried pressing the remote menu button while viewing cooltv guide? there should be an option to change program width for both large menu and small menu.
    • Mr S
      • Feb 2010
      • 52
      1) Change you settings on the display set up. Go to menu, settings and then change the display to letterbox or try another setting to make sure you get the widest possible picture.
      2) Using Cooltv you can change the view, look for 'coolswitch' when on the guide. I think its yellow as the default to change views.
      On another note you can also make it so that your PICONS show on the menu. Press the guide buttong then press menu, then go down to PICONS setting, and select the location of your PICONS.
      Regards
      • neilus0
        • Oct 2011
        • 24
        I had the same problem. Fixed it by pressing menu while in coolmans epg.
        then use the blue button to select guide
        go down to Left Width for 60 or 30 depending on which guide your using and change the number. I'm using 130 & 220 instead of the default of 110 & 190
        Red button to save
        done
