duty on dreambox
I got stung last time i ordrered a Dreambox 800hd pro from Yaoxin they marked it down as 35 dollars and i had to pay ?3.90!
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
taxes aint worth worrying about lads , its sub ?10 per unit .the worry is you loose your units to customs at heathrow as they are clamping down on clones ,
if you buy one unit it usually ships thru west midlands airport who aint got the resources to check and confiscate , just be careful if you order over 5 units and split the shipment up ,
i learnt this lesson the expensive way !
To avoid customs fees altogether get the value of any item listed as below ?18 as this is the threshold at which taxes are then impossed
.... Yaoxin are usually good at doing this but unsure if you would have problems if the carrier lost it as you then cant say is ?150+
