cross epg
  • andy91
    • 3583
    #16
    Usals should be fine in simple mode, choose postioner and put correct long and lat in and a decent set of bouquets like Catseyes or Flipflops will do the trick.
    Andy.
    • porter1
      • 559
      #17
      ill dig my lat/long out,itv hd agc only 37%,picture is spot on no probs there
      • alom5
        • 1648
        #18
        usals is the easiest. if using a motorised setup mate. just stick your long and lat in and will work with minimum fuss.
        if its a fixed dish then even easier..simple and then shoose 28.2 and thats it...dont even need usals on for it.
        • andy91
          • 3583
          #19
          On that box you should be getting near on 100% so sounds like your dish is a bit off.
          Andy.
          • satsmo
            • 6397
            #20
            Andy.
            You wont get 100% on any channel with the SE tuner, maybe you are referring to the 800 pro? On the SE with the BCM tuner,you will get a more "Dreambox" like tuner reading.
            Either way the alignment is off as the signal quality is way too low.
            • porter1
              • 559
              #21
              i had 100% on the 800 with the rev m before ithrew this on,ten mins ago
              • saj1985
                • 785
                #22
                ill have a look in a minute,struggling to get lock on sat.tune failed on some 28 east at the min,set on advanced because usals has never worked before,done my normal set up,starnge
                i got a dm800se the other day,
                was having same issue, solved by using usals instead of diseqc.
                i also was only use to diseqc, couldnt get my dm500s to work with usals!
                usals is a lot easier
                Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
                • andy91
                  • 3583
                  #23
                  Either way the alignment is off as the signal is way too low.
                  Well you learn something new every day
                  I would of thought the Se would match the pro.
                  Perhaps its not as good Alom
                  Andy.
                  • satsmo
                    • 6397
                    #24
                    It's better, the tuner readings are somewhat elevated, (for want of a better word), on the pro. Lower readings on the SE will not reflect a lower QOS.
                    • saj1985
                      • 785
                      #25
                      before i disconnected my dm500s on thor 0.8w,
                      i was getting 95% snr and 90% agc,
                      but when i put dm800se it was saying tune fail!
                      usals will solve this problem mate,
                      put it on simple/positioner then just put your long and lat in,
                      send cateyes using dreamedit (bouquets which are in sticky)
                      then select channel and away you go.
                      • porter1
                        • 559
                        #26
                        goes straight to 13 east,gets same readings 37%,but hd tune failed
                        • saj1985
                          • 785
                          #27
                          hey mate, on the dm800se menu you can choose whether to have snr or db showing on infobar,
                          but i wanted to ask, what is the value of db in terms of snr?
                          1 db = how much percentage snr, so to speak?
                          hope my question dont sound stupid
                          • porter1
                            • 559
                            #28
                            snr is 15.40 agc 37%
                            • alom5
                              • 1648
                              #29
                              i will have you know boys that you can get snr 100% and i have uploaded some screenshots previously which show clearly the snr at 100%.
                              believe me andy it's as good as everyone makes it to be.
                              and here is the link to those screenshots. thank you
                              • southpaw
                                • 2233
                                #30
                                Yep, alom is correct, pulling 100% here from a 1m dish with a 50m cable run
