Dreambox Webx-Tv and VLC help
  • pryddie
    • 55
    Hi There
    does anyone know if its possible to view the dreambox and view a channel with more than one person. ie i have my son and daughter both in Uni and when one logs on through the server page its ok but if the other one logs into it then it stops even though they are watching the same channel
    thanks in advance
  • wmccull
    • 67
    It should be possible, what guide did you use to setup vlc ?
    • pryddie
      • 55
      I havent used a guide, i d/l vlc to my daughter and sons laptop as the xweb-tv button displays missing plugins and when i try install missing plugins it says none can be found.
      So i d/l vlc put them both on the laptops, then i took an account with no-ip.org and when they log into the dreambox web interface over the web it has a vlc option to play the channel the dreambox is on, but it will only allow one user.
      thanks for your help
      • wmccull
        • 67
        I wondering if its got anything to do with compression or the fact that it may only allow 1 active connection at 1 time.
        • pryddie
          • 55
          Seems like it wont let you have more than one user, anyways i wouldnt worry i cant even get the damn thing to work outside my home network now.....
          fed up with it
