flash memory
  • 00360362878
    • Mar 2010
    • 488
    #16
    Okay mate, take it easy with the pluggins.
    Is the se a lot better than the pro, have to say the white one is a bit naff.
    • porter1
      • 559
      #17
      ye i like it lot more,images,hdd works straight away,fan control speed
      • porter1
        • 559
        #18
        further on now,tspanel has uninstaller,when i try it says could not lock/usr/lib/opkg/lock:no space left on device,i wanna clean it up,if ye have a failed download will part of that download be clogging it up aswell
        • 00360362878
          • Mar 2010
          • 488
          #19
          Hi mate
          I don't have the se but don't see why it would be different, when you reflash that will usually clear everything from flash. Do a bit of investigating, and hang fire till someone knows about the issue.
          • porter1
            • 559
            #20
            thanks for reply,ye not touching it,know if it reboots it will do the same as before,see if know anymore tonight
            ps:need to get barry allan set up i think,be safer
            • porter1
              • 559
              #21
              any ideas here anyone,cant get oled picons cos no room left
              • rapscallion
                • 141
                #22
                Porter do you have a HDD. If so use Barry Allan. Put the image on there and you can have has many add ons you want on there.
                • rapscallion
                  • 141
                  #23
                  At the very least a uSB stick so you can put your picons and epg stuff on
                  • porter1
                    • 559
                    #24
                    ive got stick and hdd,tries to put addons on stick and when it gave me the option i picked it and it said full even though i formatted it:barry allan i copied image to it and tried to boot from barry allan but fails,
                    how do i put other images on barry allan to try out,ftp?
                    • rapscallion
                      • 141
                      #25
                      Start DCC.
                      In the left hand window open the folder named MB_IMAGES.
                      Now in the right hand window select the first secondary image you would like to run in mulitboot and highlight it, then click the < button to transfer it.
                      Shut Down DCC and now go to your plug-in menu on your DM800 and select barry allen.
                      Now select wizard for images at MB_IMAGES.
                      Then select extract NFI images from MB_IMAGES.Option 3.
                      You'll now see it all happening leave it for around 4 minetes and you'll see the Dm800 reboot.
                      At start up you will see your regular boot screen followed 30 seconds or so after by the read Barry Allen screen.
                      Now select with your remote the image you would like to run.
                      Thats it you running off your Flash Drive.
                      • porter1
                        • 559
                        #26
                        hi m8,is this on ftp,settings,backup/restore,what section if ye know what i mean on dcc,cheers
                        ps:just seen it on ftp,ill have a go cheers
                        • porter1
                          • 559
                          #27
                          thanks ,it didnt reboot but i presume thats how i can send a couple over and test out and if i copy this image will it copy all ,settings etc,thanks for that
                          • porter1
                            • 559
                            #28
                            well done that,backed this image onto it aswell,got oled picons onto hdd,changed the picon settings,reboot,now its looping round again,green screen,reboot,green screen.....................
                            did get barry allan on boot when i turned it off,selected backup and it didnt work,selected flashed and it didnt work,hope im not reflashing again
                            • porter1
                              • 559
                              #29
                              well i reflashed ,everything running now,still room on the flash,all picons on,not bothered about barry allan,can addons be set so they download onto the hard drive
                              • 00360362878
                                • Mar 2010
                                • 488
                                #30
                                Porter. You are turning into a serial FLASHER mate!!
