Ok firstly you need programme dcc
>>DREAMBOX CONTROL CENTER<<
extract file and save to desk top ;;;
open the program you will see this screen
first change the language ,, you will also see a picture of a computer and a dreambox under each you will have to add the ip ,,, if you know these add them and click connect if not you will need to search use the search button ,,
once clicked a page will open as below ;;;
top right of this page it says 1-254 you can edit the 254 to shorten the search ;;
top left it says search click that ,,
a list of ip's will appear depending how many devices are connected to your network NOTE: the dm500 will not be named on the list as you see on mine its 192.168.1.8
the dm800 is named double click on the ip of yours then connect ...
that's it ,, green connections between computer and box mean you are connected
btw i have changed the password its usually dreambox ,, now i'll change it again ,,
