what sat dish to buy
  • peter800
    • 34
    which dish is best for dreambox hd is it the bigger the better and do i need a motorised dish and can anyone recommend an installer in blackpool area and how much does a dish cost to put up cheers in advance
  • dctyper
    • 2539
    i use this
    Wavefield DS 55cm Force Frontier Multi Sat Dish
    pick up loads of sats and i dont have to wait when flicking between them
    dc
    • southpaw83
      • 360
      Originally posted by dctyper
      i use this
      dc
      What satellites do you pick up with that?
      • dctyper
        • 2539
        13e 16e 19e and 28e
        it has quite a skope, someone on here has 7 lnb's
        dc
        • micflair
          • 275
          13e 16e 19e and 28e
          dc
          haha that thing is a beast!
          I live about 30mins from you OP, I have a motorised. Think I paid about 120quid for an 80cm with motor from ebay a few years ago. Will pick up a lot of stuff, but really you will only use 0.8w, 13e,19.2e and 28.2e. Not much else really worth bothering about!
          • dibble
            • Sep 2011
            • 24
            Nope, so long as it's big enough to give you a zero BER (error rate) for the satellite(s) you want, that's good enough
            No. You can just point a dish at 28E and watch S_y. If you want more sats, you can get a Triax dish of 80cm or more and a multi-LNB mounting track. That way, provided you use slim LNBs you can receive up to 4 satellites through a Diseqc switch so long as they are all >3? away from each other (and less than about 20? in total) I've got one that pulls in 28E, 19, 16 and 13 - though I did have to file down the edges of the LNBs to get them close enough..
            ... and how much does a dish cost to put up
            For a simple 45cm S_y dish, reckon on ?100 minimum for someone to stick it up for you. The more "specialised" you get the more it'll cost and the fewer will be the number of installers who would be willing and able to do the work (though you may only find out that they don't knwo what they're doing until afterwards )
            Mama's got a Dreambox ...
            • tonynw
              • Nov 2011
              • 147
              fitter
              i used this guy 3 weeks ago did a superb job
              Aerial & Technical Ltd - Home - Installers to Fleetwood, Thornton, Cleveleys, Poulton, Blackpool, Lytham, Kirkham, St Annes and Garstang
              tonynw
