Freezing and glitching badly on 28 east
This topic is closed.
  • gracieboo
    • Dec 2010
    • 368
    Hi there guys im having problems with freezing and glitching on channels on 28 east mainly the hd ones. All the fta hd channels are fine on 28 east for me. I have the latest dm 800 hd pro bought from yoaxan on 27/8/11 so i assume that it already has an rev m tuner in it and i get 100% signal. on discovery hd ecm times usally on this channel are 0.946 but can be as much as 3.150 and also says hop 2 and espn hd is reading at the minute now between 0.286 and 1.986 And gets a lot worse with a match on. By the way some of the european hd channels are great with the exception of s-y it. So basically is this my server thats not up to scratch here or is it a tuner problem. many thanks for any replys
  • smoggie
    • 863
    most likely a server problem. Most pay servers are like this going by the number of threads like yours.Try rebooting router and make sure your dont have the likes of utorrent open. Also if you are using homeplugs plugged into and surge protection extension it can cause problems
    • dctyper
      • 2539
      high ecm time is a server issue
      although an inline amp always helps the dm800
      dc
      • gracieboo
        • Dec 2010
        • 368
        Thanks guys i have an inline amp about somewhere so il put it in . Ive turned over to s-y germany here and all was fine even though the ecm time was 0.883 on hop 2 but no freezing or glitching. And now nothing open from server at all on all packages so maybe this is a server issue. The guy i get it off is rated the best on euro kings. Any suggestions for a stable line could someone private message me to point me in the right direction. many thanks
        • satsmo
          • 6397
          Payservers
          I am closing this and that's all I will say. And if anyone decides to take you up on your pm offer and sends you towards another one they should stay on the payserver sites.
