Barry Allen E2 Version 4.5.7
  • 2tone
    • 483
    got this from another forum might help some one have not tryed it yet as have barry allen running on an image but will be giving this a go at the week end to see how it go's , also when you load barry allen if you cant pick your image at the barry allen boot image do this
    1=w.i.z.a.r.d for setup
    2=RC device
    3=/dev/input/event1
    4=reboot your box
    and should work fine
    in case dosent work tray
    /dev/input/event2
    reboot your box and should be fine now
    Barry Allen for Dreambox 7025, 7020, 600 and 800
    Version 4.5.7 by gutemine from 14.06.2008
    Release infos
    0.1.0 first official Version
    0.1.1 add LCD support, copy, rename and erase
    0.2.0 add backup and more tools options
    0.2.1 bugfixes
    0.2.2 quod erat demonstrandum
    0.3.0 WebIF and Wizards
    0.3.1 nl, 12 images, bugfixes
    0.3.2 tar.bz2 images, instant extract
    0.4.0 OE 1.5 support, Flashing and user scripts WebIF
    0.4.1 keep squashfs and Barry Allen gets fat
    0.4.2 time for a new version and new language fr
    0.4.3 feeding the GNU
    0.4.4 time for a new version
    4.4.6 preliminary dm800 support
    4.5.1 DM 800 support
    Thanks to noggie for his nfi file tools !
    Thanks to DarkVolli for the enigma1 plugin !
    1) Prerequisites
    During the installation there has to be CF
    card in the Dreambox (attention: insert or remove
    into Dreambox 7025 cardreader only when Dreambox
    is turned off), or an USB stick which is successfully
    detected (in case of problems try an USB Hub).
    If Barry Allen on USB is used then put
    the CVS Image from OoZooN in Flash, because this image
    has the USB drivers permanently built into the kernel.
    If neither CF card not USB Stick are attached then
    installation takes place on the Harddisk. Because
    the images then also run from there it will run
    permanently and it could be necessary that you disable
    Harddisk Standby in the images to allow running Barry
    Allen stable from Harddisk.
    2) Installation
    First boot from Flash and then copy the file
    enigma2-plugin-extensions-barryallen*.ipk
    to /tmp with ftp (TCP/IP must be working already).
    If you have an image in Flash that offers a Blue
    Pannel Manual Addon Install, then you can use this
    functionality to install the ipk file.
    If not, then install Barry Allen by entering the
    following commands in a Telnet session:
    cd /
    ipkg install /tmp/enigma2-plugin-extensions-barryallen*.ipk
    Then restart enigma2 and the Barry Allen Plugin
    shoudl show up under Games / Plugins.
    In the Images installed by Barry Allen you don't have
    to install the Barry Allen Plugin anymore.
    The Barry Allen Plugin integrates himself into then
    automatically during the image extract.
    And you can remove Barry Allen if you are booted
    from Flash:
    ipkg remove enigma2-plugin-extensions-barryallen
    3) Usage
    There is now the enigma2 Plugin of Barry Allen included
    under Games / Plugins of the enigma2 menu,
    which offers the full functionality of Barry Allen.
    For extracting of nfi images in Barry Allen copy the
    image files to /MB_Images (normally a link to
    /media/hdd/MB_Images created during Barry Allen
    installation)
    If there are Problems with image extraction or other tasks
    with the enigma2 plugin try doing it in telnet:
    cd /media/ba
    ba.sh extract nameoftheimage
    On the next reboot this new Image should be available
    in the bootmanager for choosing to boot it and then it
    can be customized and used as usual.
    The Bootmanager now should remember the last booted
    image and hence recordings from Deepstandby should work
    now.
    Have Fun using Barry Allen on the Dreambox !!!!
  • aspr
    can not download.
    Hi. I can not download Barry Allen 4.5.7. How do?
    • 2tone
      • 483
      you need 5 posts i think m8
      • pantnick
        Hi... I made the above steps but after the installation of barry allen nothing happens..I reboot the enigma and
        everything is like before...
        • privatposta
          • Mar 2009
          sorry, wher can I find for E1, and how can I dowload? Thanks
          • caveman_nige
            • Feb 2008
            • 4920
            have a read of this to get yourself started...
            • alfiezuk
              • 21
              I have installed the Latest Barry Allen But it does not show on the Plugin Menu where can i find it.
              Many thanks
              • laqueus
                How to disable harddisk standby on a DM800 ?
                • westkill
                  • 2378
                  try
                  menu>system>harddisk>harddisk setup>then change the option to no standby
