bbc channels have gone after doing so many scan it doesnt pick up any bbc channels SCANS DONE ON THESE CONFIGURATIONS 28.2e 1N/2A/2B/2D,13E,19.2E AND 4.8E
BBC Channels gone?
try reloading sgt flipflops latest boquets..Fave replies from various threads
check here to see if it differs from yours.
Astra 1N / Astra 2A / Astra 2B / Astra 2D / Eurobird 1 (28.2E) - All transmissions - frequencies - KingOfSatComment
the sats are same but still no luck cant get the bbc channelscheck here to see if it differs from yours.
its the frequency that has to match,if the bouquet is old channels movement has happened on some channels check what setting on box and check with kos for changes.check all data on that channel.are they the only channels missing,thinking of the very high winds moving dish out of sync.Comment
guessing to put the input of frequency to match you have to manual search and put the data in ? as automatic search frequency might not match with the new one so what info do i maually put in to get bbc 1 channels etc can some post a image so i can see and match it thanksComment
Sorry what do you mean what dish is it aimed at I didn't understand I have a standard sky mini sky dishComment
ok you have a fixed dish,it was all the sats you were scanning on the first post suggested a motorized dish,what box do you have is it old?cant remember on some box a frequency is not added to the scan list so it misses that channel to scan,have you had those channels before lately?
someone mentioned an xml file not current would not scan on some channels if moved frequencies
sorry cant help anymore.Last edited by cactikid; 5 January, 2012, 01:44.Comment
I have a normal fixed sky fish owned by sky and have a dreambox se its a new box and I used to get bbc channels n hd BBC channels and I have added latest satellites xml fileok you have a fixed dish,it was all the sats you were scanning on the first post suggested a motorized dish,what box do you have is it old?cant remember on some box a frequency is not added to the scan list so it misses that channel to scan,have you had those channels before lately?
sorry cant help anymore.Comment
