moved dreambox to another area
  • punxxxter
    • 184
    hi
    i had my dreambox on a motor with a big dish,now ive moved the box to a differant area (postcode) with sly minidish already installed and receives channels on sly box.
    the dreambox has 0 signal.
    i have changed the tuner settings to single sat (simple)
    do i have to change longitude and latitude?
    is there any thing else i need to do ?
  • alotmentman
    hi mate were you moved /was the sat dish set to 28,degree set your sat in dreambox to single sat reciever then do a scan on astra 28.2....see what you get might be dish need aligning if no signal ////
    • andy91
      • 3583
      Dont have to worry about changing long and lat if its on a fixed dish as the dish cant move.
      Shouldnt need to change anything it should work fine just setup the new network of the other stuff
      Andy.
      • punxxxter
        • 184
        thanx to both replies.
        it must be the dish alignment then. last time i checked with sly box, signal wasnt the best but was receiving ok.
        dam gotta get the ladders out then and its a 3 story building
        haha....
