ts panel server down?
  • yamar1
    • 970
    can anyone confirm if the tspanel server is down, iv just reflashed my 800 and it says no internet connection or server down when i try to update the pannel, the box is connected to the net ok.
    Faster than Faster
  • potrobber
    • Mar 2010
    • 493
    you can update it thru sim 2 addons in tspanel
    • yamar1
      • 970
      thanks, i know that, problem is it wont connect it says no internet connection or server down when i try to do anything on the tspannel. just wanted confermation from a member that the tspannel is working or not and connecting as mine aint.
      Faster than Faster
      • alom5
        • 1648
        it was pissing about the other day...then came back on.....but can confirm it is down again
        • yamar1
          • 970
          thanks for confirming.
          Faster than Faster
          • Paul2482
            • Oct 2010
            i am having the same problem, i have tried to download mgcamd for sim2 server via tspanel which it does but when it installs i can find it anywhere. Hope tspanel servers come back on line soon been three days so far.
            • bebebxb
              • May 2012
              • 18
              Is it still down?I get the same error with no Addons download failure,No internet connection or server down
              • andy91
                • 3583
                Did you get your internet working on your box?
                Could be corrupt software on the router.
                What brand is it and what service provider are you using?
                Andy.
                • bebebxb
                  • May 2012
                  • 18
                  Yes the internet it is working.The router is a huawei hg655b and it is working fine.
                  I'ved downloaded some addons and there are no problems execpt the ts panel.
                  Thanks in advance!
                  • freck
                    • 1076
                    Was down for me aswell yesterday and found it strange??
                    Firstly thought it was an internet problem till i saw this thread.
                    Back to manually installing .ipk's for a while methinks
                    Freck
                    • mast
                      • Nov 2010
                      • 1027
                      Hi
                      Just checked now and can confirm its down.
                      Regards
                      • 00360362878
                        • Mar 2010
                        • 488
                        Seen a post elsewhere yesterday, they are working on it and it will be back ASAP.
                        It's not all down, you can still reach addons from other panels.
                        • satsmo
                          • 6397
                          According to mfaraj57, four out of five addon servers are still online. However the Tunisiasat server is under maintenance but should be back soon.
                          • fintannl
                            • 60
                            can you explain what this means. currently trying to download crossepg via tspanel. is this possible currently or do i need to chill for a while
                            • satsmo
                              • 6397
                              Chill for a bit or manually install the IPK version you require.
