bouquets
  • john1509
    • 215
    bouquets
    hi guys is there a guide were i can find out how to make my own bouqets tx sorry posted twice can admin remove please tx
  • satfoot
    • 23
    There are more ways than one how to go about this.
    Here is one of them which you may wish to try:-
    On your PC, open DreamBoxEdit (this is a Dreambox Channel Editor)
    Open your Channel Settings File
    Towards the top you will have three Columns:-Services, TV User Bouquet Details and Bouquets
    Goto Bouquets (right hand side)
    Right click on any Bouquet Name
    Click on Insert New Bouquet
    A New User Bouquet will be created towards the bottom of the List
    Right click on it and Rename the Bouquet as you wish, example:-Sports
    Now, if this Bouquet will include various Channels from many different Satellites, drag it towards the top of your Bouquet List.
    If it will contain Channels from just one single Satellite, drag it near the other Bouquets pertaining to that Satellite.
    Now double click on it
    Note that the Column TV User Bouquet Details is blank because your newly created Sports Bouquet has no Channels in it yet.
    Now goto the left towards the Services Column.
    Highlight the Channel/s which you wish to include in your new Sports Bouquet and drag the selected Service/s to it.
    For each Service or group of Services which you drag, you will be notified with the number of Services dragged. Example:-1 Service added to Bouquet Sports or 12 Services added to Bouquet Sports etc.
    Click Ok
    Henceforth under TV User Bouquet Details, you will be able to see the name/s of the Channel/s which you added to it.
    Now, if you will use the Sports Bouquet for Services pertaining to just one single Satellite, click on the Service tab (under the heading TV User Bouquet Details). You will be asked to confirm whether you wish to sort the services in that Bouquet alphabetically.
    If, on the other hand, you will use the Sports Bouquet for Services pertaining to many Satellites, right click on any Channel inside the Bouquet, go down to Auto Insert Marker and then click on Insert Marker at Change of Satellite.
    You're almost ready now.
    Click on Save
    FTP the Channel List to your Dreambox and click on Reload Settings on Dreambox. That's all.
    Cheers.
    • uk_rules_ok
      • 4
      i use a program called enigma edit works for enigma1 & 2, hope this helps
