Background:
I have an Amiko Alien 8900 HD set, which I use with mgcamd. The firmware I use is the default firmware" Spark".
As mgcamd was giving me lot of trouble, I chose to uninstall, and reinstall ir using the FTP programme. Even after doing that, channels never opened.
I tried and downloaded many versions of mgcamd until 1.35 version, but no luck. I updated the firmware using spark portal, but still no luck.
I decided to flash the box with Spark rescue image, and I did the following.
1. unzip spark rescue image to the fat32 formatted usb
2. Power off the box from behind, and plug th eusb drive into the box.
3. Start the box while holding the "right arrow button" in front
4. It says something on the light, and I press OK button.
5. The LED lights on the panel start showing : 7 7 0 .... 7 7 0... and so on.
6. This 7 7 0 shows for almost 30 minutes, and the system is still not flashed!
Please tell me what to do? can I also flash it using RS 232 cable? if yes what is the process?
Please help.
Please help.
