CCam.cfg prob?
  • pomster
    • Mar 2009
    • 119
    CCam.cfg prob?
    Hi people i've just set up on the sat side of things an got a strange prob! i can't edit my ccam.cfg file, yesterday i was editing no prob taking lines out and putting lines in, now i can't delete the 1 thats in the file!
    can any one help pls?
  • smoggie
    • 863
    might have gone corrupt, just make a new one with notepad, naming it CCcam.cfg and put in your lines. delete old one and replace with new one
    • pomster
      • Mar 2009
      • 119
      there are some already in there ccam.cfg0.0,0.1 ect ect, so i am ok to delete the other an use these? can i avoid it happening again?
      • smoggie
        • 863
        sometimes it just happens, dont think theres anyway of preventing it.I only use cfg file just remember to keep a back up of it for whenever anything goes wrong
          sounds like you have either A: duplicated files or B: if the CCcam.cfg files are named like this CCcam_1, CCcam_2 etc then this is normal and you have Cccam switch installed.
          Also worth noting is to use Notepad++ to read and alter CCcam.cfg files as notepad on its own cannot sometimes break the lines up correctly.
          • pomster
            • Mar 2009
            • 119
            sorry about this lads!
            What is it you back up the ccam.cfg file? the files are duplecated but what is a ccam switch? need i back em up if i have 1 of these?
              Just backup the main CCcam.cfg i am assuming that you have a backup of what is already contained within the file anyway
              • pomster
                • Mar 2009
                • 119
                Yes, each cccam file has the same stuff in just looks like a lot of helpful info to me! however each one i use becomes corrupt, not sure why, so i now make my own and leave the others alone! do i have to take the backup file of the box an keep on laptop or is it ok on box?
                • smoggie
                  • 863
                  Yes, just use DCC or any other ftp and transfer it to your laptop
                  • pomster
                    • Mar 2009
                    • 119
                    Flash fxp same thing?
                      Yes will work fine
                      • pomster
                        • Mar 2009
                        • 119
                        Cheers!
