Modifying the rcdm5xxx.xml file
  • Tomer
    • Mar 2009
    • 7
    Is there a guide somewhere that I can find about all of the XML properties?
    I'm trying to reporgram one of the buttons so it will run a script of mine (run a plugin).
    Is this possible?
    Tomer
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    There is no guide for that.
    You can change the operation of the button at the area you want. After editing, you need to upload the file to /var/tuxbox/enigma/resources because /share/tuxbox/enigma/resources is read-only.
    • Tomer
      • Mar 2009
      • 7
      Thanks for the quick reply.
      I have dug deeply into it and I came to the same conclusion :-)
      When I press the yellow button I get the plugins menu. Is there a file that holds what information to show in this menu, or a directory? Can I add to this menu another item that when clicked will run a script, and if yes how?
      Thanks again
      Tomer
      • Tomer
        • Mar 2009
        • 7
        remote control
        I am still trying to play around with the remote. Does anybody know how can I reprogram a button (whichever one) that it will open me favorite Ppanel addon?
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          You will need to know the name of the function that you want to run.
          What do you want to execute?
          What button do you want to use?
          What image are you using?
          We need as much if as possible...
          • despdan
            • 544
            Not sure if this is what your after.
            put your .sh & .cfg files in the var/tuxbox/plugins folder.
            Now when you press the yellow botton it will show in the menu then select it & it will run.
            But as Devilfish says we would need to know image & box.
            The above will work for pli on a 500
            • handyman
              • 64
              Link for the dreambox remote
              Hi i have the Digital Kaos 1.1 installed on my dreambox 500c but cant find my way round the menu on the remote control like what colour buttons are for what menu, i saw a link on this forum about two nights ago but cant seem to find it now,can you please give us the link for itif you can, please reply
              • opsmonkey
                • 5379
                you might want to check the cable section mate.. this is the dreambox satellite thread
