Dreambox ReStream 1.4.1
  • alunfennell
    • Oct 2008
    • 1525
    Just after release of version 1.4 I and others noticed some bugs.
    These should be fixed now.
    A problem was that the XAJAX framework debugging was running.
    And that can be quit annoying.
    A transcoding problem, which made it impossible to stream. Except H.264.
    Which is not correct ofcourse.
    And a new feature is that the Wowza server can now be another server
    than the webserver.
    Here you can download the PHP code for the server part. This code is
    based on PHP5 and object oriented. So you need at lease PHP 5 installed
    on your webserver. Got reports of working systems on both Windows and
    Linux. Get your version right now (06-07-2008)
    Changelog:
    06-07-2008 (v1.4.1):
    * Bug fixed in the VLC command. Side effect of the H.264 addition.
    * Disabled XAJAX framework debugging
    * New setting for the Wowza Server location. Look at the settings file.
    24-06-2008 (v1.4):
    Version 1.3 is never really released. So jump to version 1.4
    * Added flash H.264 support through Wowza Media
    * Fixed programguide
    * Added ggrab.exe option for windows
    * Some tweaking on mobile streaming. Should work on an iPhone
    * Auto play when VLC is already transcoding.
    11-02-2008 (v1.2):
    * Recordings from an enigma1 are being played. (Or should be, isn't tested yet)
    09-02-2008 (v1.2):
    * Playback of recordings (enigma2 only)
    * Play video over IPv6 if available
    19-01-2008 (v1.1):
    * Add boutiques, channel and programguide loading on an enigma1 dreambox
    * Able to watch some television
    * Fixed boutiques and channel pulldowns in IE6, and other IE7/6 html issues
    18-01-2008 (v1.1):
    * Updated the Dreambox online check. It should now work on windows as wel
    Attached File(s)
    **The Worlds Best Interactive F1 Strategy Game**
