Dreambox weird
  • joep44
    • Apr 2012
    • 5
    Dreambox weird
    Loads of channels stopped working on 28.2e so I scanned again and lost these channels during the scan, I then brought another file working drewmbox with this channels from another house which were working! They didn't work here either and now I have taken the working dreambox back to my house they are no longer working here either!! I'm confused all other channels have 95% but 200 of the others arnt working
  • andy91
    • Aug 2010
    • 3583
    Lots of things could be the problem start with an uptodate set of bouquets and take it from there.
    Catseyes does a great multisat one and i recently modified a slyuk only one in downloads courtesy of Catseyes.
    You will have to wait a bit to download.
    Andy
    • joep44
      • Apr 2012
      • 5
      It's happened to a working box as well from another house and after it been plugged in here and took back same problem with that as well its showing 63% signal on most channels! But loads 91%
      • andy91
        • Aug 2010
        • 3583
        Signal aint good could be dodgy power supply,faulty tuner or not sitting correctly, bad connections,dish out of alignment lnb on its way out.
        You have to eliminate a few to work it out.
        I always start with poer supply cos they tend to go.
        Andy.
        • joep44
          • Apr 2012
          • 5
          I agree with what your saying but I'm in my friends,
          This is we're the problem is, so I brought mine that's been working in my house the channels ain't working on my dreambox either
          And now Ive brought mine home the same problem is now happening in my house were it was fine until I tried it there?
          • andy91
            • Aug 2010
            • 3583
            Did you use the same power supply?
            A faulty one goosed my motherboard.
            Add them bouquets with dreambox edit and take it from there.
            You could try a reflash.
            To add when you say not working do you mean paid channels?
            Is the network set up correctly and the thing we cant talk about on here working
            Andy
            • digicon
              • 8261
              Sounds like it could be the LNB at your friends house if the amp has gone you could lose channels that where low on signal anyway but now have gone due to the LNB
              • joep44
                • Apr 2012
                • 5
                But now I'm
                Home shouldn't they be working? But there not after trying it here
                • andy91
                  • Aug 2010
                  • 3583
                  But now I'm
                  When you say not working do you mean tune failed no signal or black picture.
                  Do a network test and see if youre connected.Menu/setup/system/network/network test.
                  Andy.
                  • joep44
                    • Apr 2012
                    • 5
                    I mean no signal on certain frequencys!!
