DreamUp problem HELPP :(
  • Teodorbt
    • Jun 2013
    • 5
    I want to flash image for my dreambox 800hdpvr and I have a problem with dreamup it show me a message Error cant find any com ports - aborting !
    The error is from your computer. I take it you have a serial port and set dreamup with the correct com port on your computer? Can you use the web method for flashing DM800's?
    • Teodorbt
      • Jun 2013
      • 5
      No friend my dreambox is dead because i flash other bootloader
      • Teodorbt
        • Jun 2013
        • 5
        did u know how to solve this computer problem ?
        • gaelicred
          • Feb 2013
          • 49
          There might be some conflict with the serial port. try this :
          Control Panel> System > Hardware > Device Manager > Ports (Com&LTP) > com port > properties > port settings > advanced > com port number > and change from comp 1 to com 2 (your motherboard may just have 1 connector, the change is just logical not physical, or at least the external connector is the same for com1 & com2.)
          If no joy there try flash wizard pro ?
          • Teodorbt
            • Jun 2013
            • 5
            I have windows 7 and there arent Ports (Com&LTP)
            • gaelicred
              • Feb 2013
              • 49
              Did you try flash wizard pro ? , do you know anyone that would have a desktop running xp that you can use ?
              • Teodorbt
                • Jun 2013
                • 5
                dreambox is dead | I can flash with that program ??
                • gaelicred
                  • Feb 2013
                  • 49
                  How do you mean " dead " when you plug it in is there anything on the oled screen ? I haven't used flashwizard pro so can't comment on that but i think other people use it .. any harm in trying ?
