saving transponder scan
  • gigsy
    • Apr 2009
    • 15
    hiya
    ive just done a scan on 28.2E and its found all the channels however when i went to powered the device off and back on again it had lost off the list and basically started from scratch again. Is there a way to save the info
    do i need to do a reboot from within the settings to save the new information?
  • krazylegz
    • 2834
    the settings should automaticly be saved in the memory m8, rescan then restart using the remote, if they disappear again i'd reflash the image and start over, and they they still disappear after a reflash then you'll have to conclude that your box is faulty m8
    PS3= krazylegz120282
    • gigsy
      • Apr 2009
      • 15
      so powering off from the mains without a remote control restart should still keep the info that been putonto the box?
      cheers matey
      • deskag
        • Jun 2009
        Hi m8.
        I would start by installing dreambox edit, where you can backup all your settings and ftp then back immediately, so you do not have to do all the work from the beginning. It has the added bonus of easily editing channel types etc.
        Better do the first reboot from the remote "properly" and not from the mains.
        Also new here, but this is from what I have understood so far.
        • opsmonkey
          • 5379
          cheers matey
          you have to remember that the Dreambox or Linux box is in essence a mini computer.. if you just unplug / replug it from the mains you arent shutting it down properly.. your pc doesnt like it and neither does your DB.. reboot via the remote control and settings menu..
          if it keeps loosing your channels reflash.. then rescan.. if it happens again as Krazy says your box is duff..
          • gigsy
            • Apr 2009
            • 15
            thanx guys, yep did a reboot from the control and all is sorted now. Thanx for your help
            • opsmonkey
              • 5379
              no probs.. thanks for letting us and others know how you sorted it.. the ammount of people who never report back is amazing
