addons and plugins servers
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • Aug 2008
    • 5611
    does any1 know the server details which i can enter into my DM so i can download addons and plugins from gemini and PLi servers?
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
  • Curious123
    • 2591
    If you have the Pli image loaded than you can download directly from their image server otherwise it maybe difficult.
    • .: JaCkPoT :.
      • Aug 2008
      • 5611
      im fed up with PLi..nomatter what i do even the hel you suggested about downloading cccam from server i still cant get it to work!
      ___________________
      DM800s HD
      Openbox S10
      TM500
      DM500s
      Maxx 110cm Dish
      • opsmonkey
        • 5379
        take a look at advice Curious has given in the past.. your problems will probably be down to user error.. just chill and take your time, start from the begining and dont rush
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          Nabilo Darkstar...can't go wrong with that.
          • satman
            • 736
            There all good images,
            in all fairness, if you cant get it working with a simple download from pli panel, what makes you think changes the image will help?,, you need to take your time, and think about what your doing wrong, and follow what me and curios were trying to say to you step by step!.
            boom!
            • .: JaCkPoT :.
              • Aug 2008
              • 5611
              Well i would love to have darkstar2 operating but when i flash it the box boots but doesnt start..the startup screen just comes on for 5 secs then goes for 5 secs then continues doing this..whats wrong with the image or what am i doing wrong?
              Is there anyone here who is using pli, gemini 4.2< or Nabilo image who through msn can talk me through what i need to do after a fresh flash? Through msn?
              Ive tried pli about 6times got it to work once with cs but stopped working suddenly!
              ___________________
              DM800s HD
              Openbox S10
              TM500
              DM500s
              Maxx 110cm Dish
              • opsmonkey
                • 5379
                the complete proceedue for flashing your box can be found in the first part of this document..
                read it through then follow it step by step mate.. if anyone was to MSN you they would only be telling EXACTLY what is written here..
                ps your box is up and working fine i can see you with CCcamInfoPHP
                • .: JaCkPoT :.
                  • Aug 2008
                  • 5611
                  I know how to flash it but sometimes i get bad flashes..but that not my problem..i can flash any image which i wish i could get to work with my needs..when pli is on the box there are new parent directories like var_flash and i dont know what to do with that even though when i look in their and go to the etc i find the cccam config and go the bin folder i see the bin file although i never put Them there and i got told to download of server So it must go there automatically
                  ___________________
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  Maxx 110cm Dish
                  • Curious123
                    • 2591
                    The only directories of interests to people like you and me are the var/etc because that where the cardsharing config file and satellite.xml file are usually dumped. the var/tmp directory is used to dump .gz files for manual installations of plugins. The var/keys & var/scce folders is where the keys are sent the rest of the folders are usually irrelevant unless you are satman or df as they build images. The dreambox needs attention to detail and patience at the begining but the quicker you try to run with the detail the longer it takes to do everything.
                    • Curious123
                      • 2591
                      I can go wrong with that one. Everytime I use that image it screw up either my 28.2E or my Canal+ on 0.8W and I end going back to pli.
                      • .: JaCkPoT :.
                        • Aug 2008
                        • 5611
                        I will try pli later again
                        ___________________
                        DM800s HD
                        Openbox S10
                        TM500
                        DM500s
                        Maxx 110cm Dish
