NULL MODEM CABLE
  • dazmaul
    • Mar 2009
    • 61
    NULL MODEM CABLE
    Where can I get a "NULL MODEM CABLE" from?
    I need one to reflash my box which won't boot.
    What type will I need?
  • solestorm
    • 4
    USB to Serial Null Modem Cable EuroVox Upgrade Lead on eBay (end time 10-Jul-09 16:16:12 BST)
    ebay seems to be a good place ive ordered one from above link
    • terriers
      • 580
      Or go to your local maplins store..they always have em in stock..
      • opsmonkey
        • 5379
        if you have a serial port on your PC then get a direct connection one like this..
        Null Modem 1
        If your PC only has USB then use this in conjunction with the above lead..
        Null Modem USB Adapter
        • dazmaul
          • Mar 2009
          • 61
          OK I now have my NULL MODEM CABLE and I will try and flash my box tonight.
          When I re-flash the box will I need to re-scan all the satellites I have already scanned. If so, is there a way round it, i.e by copying the satellites.xml file from the box - if so, how can I access the file when connected via NULL MODEM CABLE.
          Also, I was using a version of Gemini image and I am thinking of switching to Nabilosat BlackHole instead - will CCCam work on this image?
          Does anyone have any thoughts on using BlackHole instead of Gemini?
          • caveman_nige
            • Feb 2008
            • 4920
            if you connect your box via ethernet cable then you will be able to backup your bouquets and xml files etc but not with a null modem cable..
            • dazmaul
              • Mar 2009
              • 61
              Is that just a case of plugging the ethernet cable into box and into the laptop then using DCC?
              Or is there something else I need to do?
              • westkill
                • 2378
                you need a crossover ethernet cable to do direct from box to lappy
                or
                normal ethernet if out of a router to lappy
                • dazmaul
                  • Mar 2009
                  • 61
                  Can I do that even though the box won't boot?
                  i.e Ping into 192.168.0.2 on my LAN (which is the static IP address)
                  • dazmaul
                    • Mar 2009
                    • 61
                    I have just pinged into my box. I held the power button as it loaded.
                    The Web interface has come up and the titlebar says: Dreambox DM600PVR Web Interface... my box is supposed to be a DM800 is this just the web interface version on the box or does it sound like I've been fiddled?
