I am trying to download the Tunisia-sat dreambox player from the url in the first post, but when i am trying to unrar it, it says that it is bad CRC
Dreambox streaming to internet,it was never easy like this
thanksI am trying to download the Tunisia-sat dreambox player from the url in the first post, but when i am trying to unrar it, it says that it is bad CRC
sorry it is fixed now
Tunisiasat dreambox player and webstreamer 6.03
4shared.com - online file sharing and storage - download Tunisiasat dreambox player and web streamer6.03-portable.rar
MEGAUPLOAD - The leading online storage and file delivery serviceComment
excellent, it now works with the unpackingthanks
I got some questions
I'm using a DM600.
As so many others I find this program very interesting, so first of all thanks for the effort Mfaraj.
I don't understand all of the aspects of this program though, you can rough say (I'm technically retarded
I guess the Idea of it is to please users that don't have 100/100 connections so they can watch there dreambox from everywhere.
If you got a normal connection, do you have to have a computer at home that is on re-streaming to be able to watch this program away from home?
I get this to work without that though, I just download the software at the computer where I want to watch, Without using a server for re-streaming. But it only works with the WIN media player, with VLC I get lagg.
When I do that, just watching, no restreaming. Am I watching with the original format RAW then? Or do the software do something to the format even then?
Because it's odd that I can watch the streams with your software (not re-streaming) with windows media player, but I can't watch it with VLC in the web-x, (or in your software)
And my other question is , is it possible to get subtitles with your software with mediaplayer? AND again, I'm not restreaming, just watching.
Kind regards NikkiiComment
Thanks Nikkii
Usually dreambox stream in ts format and this displayed properly by vlc and and not appropriate for windows media player without using external codec(bitocontrol direct show used with program)
i found that windows media player more sensetive in detecting dreambox stream than vlc so i have used it by default for enigma 1 dreambox like dream500,vlc is very compatible with enigma2 dreambox like dm800
regarding streaming outside the home vlc is better than windows media player .
if you have good internet speed(upload speed) you can restream dreambox everywhere by simple steps
regarding subtitles and i have not found anyway to include them in windows media player,hope if will find anything in wmp12
regardsComment
First of all thank you very much for excellent solution for streaming.
I am almost happy now as things are working almost correctly. Here is the description of my case.
1. The streaming PC is Macbook Pro with ParallelDesctop and virtual windows xp sp3 on it. Dreambox is dm800. Have tried practically all of your versions 5.02, 6.03 portable, 6.000F with same result - after connection to dreambox some channels are streamed correctly (most of them), BUT some just give colored stripes with normal sound.
2. Starting web receiver remotely with your dreambox web receiver, installed on Toshiba r500 (win xp sp3), i can get any channel remotely i want by selecting from menu and pressing streaming button. Quality is OK even for those channels which are giving stripes at the same time on MAC computer. Have checked streaming on my iphone and also everything is ok.
3. So practically i can try to go for some trip away and use my dreambox anywhere. The only problem still why i get these color stripes on some channels instead of normal picture. Have tried in Low, Med and Advanced modes with same result
Thank you in advance for some advise
P.S. I suspect it is the problem of using of virtual windows xp on MAC, because if i install the programs 5.02, 6.03 port or 6.000F on Toshipa laptop they are working correctly - no any stripes on any of selected channels.Comment
Hi all i have set this up it runs on my local network but i want to stream and view via media player for my farther inlaw in the usa, when i click restream on the its says about registering at justin.tv??? what do i need to do i can control it etc turn it over via local ip i have entered the dns in re stream section of settings also..Comment
Thanks nixus
The reason mostly from dreambox image or the channel itself because the problem occurs not all the times and the stength of channel signal is not same for all channels
if your are using multiboot(images in usb) you can test with different images.
regarding web receiver it is designed to receive mms streaming format and not http format,this will be fixed in next web receiver version
regardsComment
Just uncheck stream to web tv from settings
Right ok thanks getting some where, now when i click start streaming i get vlc pop up viewing from my internal ip 192. how do i connect now from another pc at another destination... i tried loading windows media player and mms://******.dyndns.org:1234 witch that is what is in teh strem bit of the program but no joy..Comment
Please try with antivirus program disabled - it can block the port, as it was in my case. After disabling Kaspersky i was able to get confirmation with 1234 port checking tool, supplied with a program (press the ? symbol on the right of the small window with 1234 port in it)Right ok thanks getting some where, now when i click start streaming i get vlc pop up viewing from my internal ip 192. how do i connect now from another pc at another destination... i tried loading windows media player and mms://******.dyndns.org:1234 witch that is what is in teh strem bit of the program but no joy..Comment
Thank you very much mfaraj57. Have tried with several images but result is the same. I am attaching the pictures of the problem:both channels are from13EThanks nixus
regardsAttached FilesComment
