Dreambox streaming to internet,it was never easy like this
  • kotten
    • Aug 2009
    • 5
    #436
    I tried this excellent software yesterday, but have some questions. I got it to work both on LAN and also from internet.
    1. I have 100/100 internet at home, how can i setup the software to get the best picture?
    2. I thought i could take this software to any computer (not on the lan at home) at work for example and start streaming, but if i have understood correct, i must start the program on a computer at home and then click on restreaming and then i can open VLC on my computer at work. This mean that you got to have access to the home computer to get this to work? Otherwise how can you start restream if you dont have the program
    3. How can you change channel from a internet based computer? Must you connect to the home computer? Or can you maybe connect to dreambox webinterface and change the channel in this gui
    • nixus
      • Mar 2010
      • 8
      #437
      Hi m8
      All answers to your questions are in this thread:
      1. Use advanced mode in program to experiment
      2. Youŗe right - just open vlc at work PC and open Network stream, where select HTTP and type xxxxxx.dyndns.org:1234 and hit play. xxxxxx should mean your registered host name on dyndns.org
      3. find somewhere in this thread the web receiver program of the same genious author and install it at your work PC. In this case you even may not press restream button on your home PC
      • mfaraj57
        • 557
        #438
        Thanks for all
        Tunisiasat web receiver program 5.0.2
        This softare installed in remote pc to control the streamer porgam and indirectly dreambox,receive stream from streamer in mms format only
        link1
        link2
        • kotten
          • Aug 2009
          • 5
          #439
          Originally posted by nixus
          Hi m8
          1. Yes, i have seen this advanced, but my question was if someone has a good setup to use with high internet speed. Why invent the wheel once again.
          2. ok, i have to have the program started at my homepc
          3. Thanks author for the program, i will try this today at work
          • kotten
            • Aug 2009
            • 5
            #440
            Originally posted by mfaraj57
            Thanks for all
            link1
            link2
            I have now installed this at work, but i dont understand how it can reach my dreambox. If i press settings, the only thing i can change is DNS, port and streaming port. I can reach my dreambox webinterface from internet, i mean it is reachable on port 80
            I feel i should also send my credentials to the drambox
            • mfaraj57
              • 557
              #441
              Thank you very much mfaraj57. Have tried with several images but result is the same. I am attaching the pictures of the problem:both channels are from13E
              This is first time encountered such error
              accepted explanation that the structures of stream for some channels confilcted with display adapter drivers in mac pc
              • mfaraj57
                • 557
                #442
                we have two programs web streamer and web receiver
                web receiver software designed to work in remote pc to control streamer which in turn control dreambox
                The web receiver program interface is nearly similar to streamer except has green backgrounded colour
                The functions of receiver are stop and start streaming in streamer,start recording channels in home pc,switching channes in dreambox
                receiver also is cabable to receive stream in mms format only
                to say that receiver program will control streamer remotely and control dreambox indirectly without using webinterface,there are few minor bugs in receiver porgam and as remote controller should be wait few seconds between sending commands otherwise will not work efficiently
                receiver program connects with streamer program through port 5678,so this port should be opened and forwarded toward streamer pc ip like port 1234
                You can install receiver program in same pc with streamer and you if it works then everything will be ok and you can install in remote pce
                this picture for streamer and receiver in same pc
                this is picture taken for receiver program controlling streamer program more thousands mile far
                The program came with three preset values for choosing the best codec values better for streaming as well as advanced options for playing with different values,you can choose low or medium or high upload speed profile according to your internet speed and usually stream to mobile and stream to web tv boxes should be unchecked by default
                In general for advanced option we should follow these rules
                1-streamer streams usually in tow popular formats(access) http and mms(or mmsh both same),windows media player can receive in mms format vlc can receive both and for mms
                for http format we can use
                2- with http access we can choose and encapsulatation(ts,ps..) with any video codec and best is h264
                3- with mms access or format the better choice is asf/wmv with video codec wmv2
                regarding others like video scale better not to choose value above .5 and choose video bitrate according to your internet upload speed,you can choose video bitrate above 1000 for high internet upload speed( you have to test for that and see the quality for stream)
                for stream audio is less sensetive for the audio values and chosen audio codec you can test may value tell you get good stream sound
                for success of streaming port 1234 and assigning dns are neccessory and if these accomplished well then streaming is directforward
                you can test for port is opened or not from setting by portchekcer tool and for dns assignement
                • mfaraj57
                  • 557
                  #443
                  to connect receiver with streamer port 5678 should be opened and forwarded to streamer pc ip(in streamer side pc ) like port 1234
                  you can open receiver in same pc with streamer and to test if it is working or not
                  • nixus
                    • Mar 2010
                    • 8
                    #444
                    Thank you my friend, but can we dare to have one day your programs reworked for mac os. This would be the best
                    VLC for mac os exists and works very good
                    • mfaraj57
                      • 557
                      #445
                      To demonstrate web receiver program
                      run web receiver program
                      filling in settings these values
                      dns address: drfaraj.dyndns.tv
                      stream port : 1234
                      dreamport : 80 (optional)
                      the web receiver will connect with my streamer program and will display my dreambox channels as well as you should receive radio channel(my upload speed is low so difficult to stream tv channel)
                      ot fill this in windows media player in file-url
                      mms://drfaraj.dyndns.tv:1234
                      feedback is important
                      this test will be for 2hours only
                      • nixus
                        • Mar 2010
                        • 8
                        #446
                        To demonstrate web
                        Hi, success here in Latvia (near Baltic Sea) I have 10mbit DL and 512kbit upload, but media player interrupts often and show a lot of " Buffering...." and "Reconnecting.." But can see some ornaments and radio voice
                        P.S. I would say that the picture is better than audio - this is more audio which disappears
                        • mfaraj57
                          • 557
                          #447
                          Hi, no success here in Latvia (near Baltic Sea) I have 10mbit DL and 512kbit upload, but media player only show " Buffering...." and "Reconnecting.."
                          Did you connect with my streamer
                          to receive my stream you need not high download speed and 10 mb if more than enough to receive upload speed is not important
                          you can try now
                          i am broadcasting bbc radio now
                          just fill the information above exactly
                          Now broadcasting stopped
                          • nixus
                            • Mar 2010
                            • 8
                            #448
                            you can try now
                            No i was connected with media player, but doesn't matter - here is everything working andt on Sunday i'm going to Brasil and Argentina and am very eager to know how it will work there. Hope that my home dreambox and Mac will not suffer from electricity or networking faults.
                            • nixus
                              • Mar 2010
                              • 8
                              #449
                              Hello Boss!
                              So excellent news at the end of the day - have updated the firmware of the router (Apple Air Extreme) and made a full reboot to it - and o, miracle, things back to normal - no one glitch or problem at all.
                              Thank you again for the excellent and elegant solution and wish me success in Brasil for testing it at 12000 km away from home with dreambox,
                              • mfaraj57
                                • 557
                                #450
                                nice ot hear that nixus
                                happy streaming
