A Question"
  • robbi
    • 16
    A Question"
    I put new cam, Cccam2.1.1.2 in var/keys, var used showed 96%. I went softcam page Cccam2.1.1.1 was sill in there after I deleted it. And I could not find or see Cccam2.1.1.2. Where did I go wrong? And even if I get cam right will I then get TV? or do I need a card to work with cam? I do not have broadband either just dail up. Do I need to be online when I do this. ??
  • dowlinr
    • 226
    If you haven't got broadband the only channels you'll see with cccam is channels that can open with keys, which isn't a lot these days (Digitv on 1w)
    Your other option is to buy a card for the package you want to watch.
    Btw if you put cccam 2.1.2 in /var/keys then it's in the wrong place. Download cccam through the image you use and it'll autoinstall to the correct locations.
