Help needed
  • mac2kw
    • Nov 2014
    Help needed
    i have a dvb800 hd pvr
    and i have flashed it with the wrong image
    and now has error no ca found
    how do i resolve this
    is this a clone box firstly it had nemesis on it
    sim says dm800 11486 sim210
    and help would be greatly appreciated
    step by step detailed instruction please after all i am a newbie
    thanks in advance mac2kw
  • mac2kw
    • Nov 2014
    Can someone recomend an image based on my dvb800 hd pvr wit dm800 sim 210 sim ?
      Yes your Box is a Clone as it has a SIM210 card in there, no one can really recommend an image until you find out what bootloader you are on at the present time as most newer images will also require a Bootloader update as well
      • mdt
        • 3034
        this guide is for the DM800HD but should suffice for the se
        1. connect via serial using NULL Modem cable and Ethernet to router and pc..
        2. load patched version of dreamup, select your com port and then click connect and power on dm800
        3. when initialised it will display http serial mode on lcd and show dhcp ip once ip is displayed dreamup as served its purpose and now its in flashmode
        4. log into web browser on pc using the 192.168.x.xxx address on LCD disply and flash as normal
        DreamUP Patched dm800 clone - Downloads - Digital Kaos
        regards mdt
