Live on Sat v1.00 E1 plugin for Dreambox
  • alunfennell
    • Oct 2008
    • 1525
    Live on Sat v1.00
    Full launch coming soon
    This Plugins, list for You all Football on Satellite TV and You can go directly to them. So from now You dont need PC to use it to search for Feeds. But, first things first.
    Installation:
    * Extract archive livefeeds.zip and You will see two files ( livefeeds.plugin and plugins.lst ).
    * Copy that Files to USB or simply transfer them by FTP to /tmp folder of Your Dreambox or AzBox HD, and now enter on TV in Plug-ins, press Red Button on Remote controller to add plug-in.
    * If You are using USB select to install it from USB, or if You transfered files to /tmp folder install it from tmp folder.
    On top you will see horizontal menu with color filter ***s.
    * Red button = all (HD channels are red)
    * Green button = all (channels on 1W, 13, 16, 19E are green)
    * Yellow button = all (channels on 13, 16, 19E are yellow)
    * Blue button = all (channels on 13, 19E are blue)
    For example if you click on blue:
    Blue channels = 13, 19E!
    But now, if you press OK button you will see detail list with frequencies, polarizations, ...
    You can back with OK button again!
    Please Note:
    This is only starting and is not fully functional at the moment, all functions will become live over the next week or so !
    Regards:
    Alun
    **The Worlds Best Interactive F1 Strategy Game**
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5611
    Will this work on tm500?
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • alunfennell
      • Oct 2008
      • 1525
      I believe its open to all E1 receivers its not specific to one receiver, If you have any difficulty I would sugest opening up the different folder's and FTP the different files into manualy in the different VAR folders on your receiver....
      Did you get a TM500 Jackpot ? if you did how is it Vs a Dreambox or other ...
      Regards:
      Alun
      • piptaps
        • 399
        the plug in is available on my yellow button but its saying plug in loading failed.
        Maybe this is due to the service not live yet.
        Great plug in
        • piptaps
          • 399
          these 2, livefeeds.plugin and plugins.lst, are not inside the file attached above. instead there is liveonsat.so and liveonsat.cfg . I have then ftp these 2 into var/tuxbox/plugins
          • rruunneerr
            • 62
            Hi Alun,
            any change of an E2 plugin for the DM800?
            This would be really hand to have.
            Cheers,
            Kev.
            • kato75
              • Sep 2009
              Hi
              It's not working on dreambox 7020 ?
              • alunfennell
                • Oct 2008
                • 1525
                Like I posted above if it will not extract on the image you are useing ! open the folder up and FTP the contents of each folder to the corresponding folder in VAR etc on your dreambox.
                I had to do this and It works great on a Dreambox 500 running Nabilsat Darkstar 2 ....
                Just extract it and place contents of each folder in manually, I am sure over the coming weeks it will become available for many other images in a Plugin for direct download...
                Regards:
                Alun
                • Evilbert
                  • 114
                  Hi Alun, i've had to FTP this across to the box to get it to work, however, mine looks different to the screenshots you have posted. Also, its listing what satellites and games are on, but its not bringing up the teams who are playing any ideas? Cheers, Bert
                  • Evilbert
                    • 114
                    Should have probably mentioned i'm running Pli image on dm500
                    • .: JaCkPoT :.
                      • 5611
                      Reupload due to missing file.
                      ___________________
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      Maxx 110cm Dish
                      • dowlinr
                        • 226
                        doesn't work properly for me. It downloads the images (I can see them in my /tmp) but it doesn't display them.
                        • .: JaCkPoT :.
                          • 5611
                          I have it working on the TM500. You need to make sure that you have all files copied into the right directory.
                          ___________________
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          Maxx 110cm Dish
                          • dowlinr
                            • 226
                            All installed in the correct locations, I copied everything in the zip to the dreambox.
                            It works but I just cannot see the images (eg the matches). I can see all the text telling me which channels, frequencies and encryptions just not what match is on them .
                            • .: JaCkPoT :.
                              • 5611
                              I had tbhis prob the other day. its a problem with the RSS feed being used.
                              ___________________
                              DM800s HD
                              Openbox S10
                              TM500
                              DM500s
                              Maxx 110cm Dish
