DreamBox - What is it?
  • AndyXS
    • Sep 2009
    • 11
    What does a DreamBox do?
    Is this just a basic satelite receiver?
  • firestorm
    • 1550
    a dreambox is a linux pc with a sat or cable tunner it is the same size as a normal sat reciver
    with it being a linux based pc you can alter files even create your image
    • AndyXS
      • Sep 2009
      • 11
      What are the benefits or doing this though?
      • skegsagypsy
        • Aug 2009
        • 1230
        sorry andy but if you don't understand the benefits of doing this or of owning a dreambox you need to do a bit of reading, check out the posts in the dreambox forum and all will become clearer, you should then understand the benefits and will I'm sure be rushing out to purchase
        Oh apart from the obvious the benefits are purely educational, its all about learning andy
        'If you are neutral in situations of injustice, you have chosen the side of the oppressor. If an elephant has its foot on the tail of a mouse and you say that you are neutral, the mouse will not appreciate your neutrality.'
        -Bishop Desmond Tutu
