Hi Need to reset factorydefault
New to the DreamBox 500
read here
How Do I Use Dreamup? If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug
