I've just set this up and I'm quite impressed so decided to add a little guide.
1: Download sql epg via the blue button (addons/plugins-->SQL EPG Import plugin 1.2)
2: Set up a network mount point and connect to it.(system settings-->network mount)
3: Press the blue button and select System Settings --> EPG. Now set it to look at the SQL lite database and select your network mount as the storage location.
4: Set up SQLEPG plugin - press the yellow button and select it. Set the following settings:
Package - radiotimes UK
Time offset: 0
Number of days: 1 (saves time, it gets slow otherwise)
Use cron: ticked
Update at: whatever time you like (or if the pc you mounted is not always on set a time it will be on)
Now press the green to save.
5: Select the SQL EPG plugin again and set up the channels you want to download the epg for by pressing the blue button.
The Radiotimes channels are listed on the left window, on the right is the bouquet you are currently in. You need to map these channels to your own channels. For example my dreambox lists BBC1 London but the Radio times has it listed as BBC 1 London and south east. To map them select the radio times channel (by browsing to it and pressing OK) and the focus will now be on the right hand window where you select your dreambox channel (by pressing OK).
After you have finished press Green to save.
6: Go back into the plugin setup and select Retrieve. This may take sometime as it will download the EPG for the channels you have mapped.
Time offset: 0
Use cron: ticked
