Guide to install Crossepg with Gemini enigma2 images - 7 day Sky EPG
  • targettarget
    • 69
    #16
    This fails on Gemini 4.7 on DM800
    • sidsharp90
      • Mar 2010
      Hello to all iam new to the forum,could someone help me please. i have the dm8000 could some nice person help me set this box up for the first time please whats the first step.
      Regards
      simon lloyd
      • targettarget
        • 69
        #18
        Regards
        simon lloyd
        read the stickies.
        • targettarget
          • 69
          #19
          Ok so I fixed the script so now it downloads the EPG for Sky UK to my harddrive. It works fine. I am missing about half the channels epg.
          This is on Gemini 4.7 clone DM800
          I will provide the result once I have it all working correctly. I need the following;
          1. a complete 28.2 lamedb - a very recent one please
          2. I need the latest bskybsat-channel_list.conf also please.
          The whole process takes about 1.5 hrs to get the full EPG.
          I have only configured this for an internal HD but there is just a few path changes if its for elsewhere.
          • targettarget
            • 69
            #20
            basically this is how to do it.
            Trumpton Blog - LTImage Installation on the Dreambox
            just make sure all your paths in the config file and the files here point to the correct place and hda1 if internal hard drive for example.
            • targettarget
              • 69
              #21
              the reason why your box won't reboot is that you edit the file and ftp it back.
              I had to use vi to edit the file on the unit. the enigma2.sh file
              to open
              vi enigma2.sh
              to insert
              i
              type in what you need
              to stop editing
              esc
              to save and quit type
              :wq
              • targettarget
                • 69
                #22
                Originally posted by Sicilian
                This guide is based on a Satellite Enigma2 Dreambox with latest Gemini image installed.
                Dreambox must have a HDD installed although a DM7025 can be set to use a CF card for the epg.
                1. Transfer crossepg-enigma2_0.3.2-svn-33_mipsel.ipk to /tmp/
                2. Using blue panel file manager navigate to /tmp/, then highlight crossepg-enigma2_0.3.2-svn-33_mipsel.ipk and press green button to install.
                3. Using you favourite ftp program navigate to /usr/bin/ and transfer enigma2.sh to your desktop.
                4. Now again using your favourite ftp program navigate to /usr/crossepg/ and copy crossepg_epgmove.sh to you desktop.
                5. Using a unix compatible editor such as crimson editor attached edit enigma2.sh as follows: -
                Under #Scripte copy this line /usr/crossepg/crossepg_epgmove.sh start
                So it should be something like this: -
                PHP Code:
                #Scripte
                /usr/script/syslogd_script.sh restart
                [ ! -e /proc/fs/nfsd/exports ] && /usr/script/nfs_server_script.sh start
                /usr/script/inadyn_script.sh start
                /usr/script/httpd_script.sh start
                /usr/script/djmount_script.sh start
                /usr/script/ushare_script.sh start
                /usr/script/crond_script.sh restart
                6. Again using a unix compatible editor edit crossepg_epgmove.sh, edit the paths to suit your image, but with Gemini images it should look like this: -
                PHP Code:
                #!/bin/sh
                HOME=`echo $0 | sed "s/crossepg_epgmove\.sh//"`
                if [ -f "$HOME/crossepg.config" ] # if configuration exist
                then
                    DBROOT=`cat $HOME/crossepg.config | grep db_root= | sed "s/db_root=//"`
                else # else default path
                    DBROOT="/media/hda1/crossepg"
                fi
                if [ -f "$DBROOT/ext.epg.dat" ] # try on configuration path
                then
                    echo copying ext.epg.dat from $DBROOT
                    $HOME/crossepg_epgcopy "$DBROOT/ext.epg.dat" /media/hda1/gemini.epg.dat
                elif [ -f "/media/hda1/crossepg/ext.epg.dat" ] # if we have a bad path try with default path
                then
                    echo copying gemini.epg.dat from /media/hda1/crossepg/
                    $HOME/crossepg_epgcopy /media/hda1/crossepg/ext.epg.dat /media/hda1/gemini.epg.dat
                else # no epg found
                    echo ext.epg.dat not found
                fi
                7. Ftp your edited engima2.sh from your desktop back to /usr/bin/
                8. Ftp your edited crossepg_epgmove.sh from your desktop back to /usr/crossepg/
                8. Reboot your dreambox.
                9. Once rebooted goto Menu and you will now see Crossepg in Setup, so press Menu>Setup>Crossepg and adjust settings to suit. You can set to update daily & use CF card for epg if installed.
                10. Press Green button for plugins, select Crossepg. Dreambox will now switch to hiphop music channel and update, then automatically switch back to tv channel once updated. At the end of the process the dreambox will reboot.
                11. Enjoy 7 days worth of EPG
                Tools Crimson editor and Crossepg attached.
                works with gemini 4.7 clone dm800 if you edit the files directly with vi
                • targettarget
                  • 69
                  #23
                  also see last post on this page
                  CrossEPG (enigma2) with 7 day HD EPG - Page 2 - Austech
                  • maxinho
                    • Apr 2010
                    • 15
                    #24
                    great bit of software, but i cant get it to work correct or it is me.
                    i have the cross epg plugin on the green button.
                    it goes to a radio mode downloads data and then just stops.
                    i am using a onboard sata drive
                    is this text right DBROOT="/media/hda1/crossepg"
                    fi
                    any ideas?
                    DM800 HD Original with 500GB internal sata drive ( Dream elite black hole 123a ) with a Triax 1.1 motorised dish
                    • dimon254
                      CrossEpg wand 28,2E not works
                      It works with 13E. When it tries to get epg from 28.2E, the picture just dissapears and I see window "starting downloader"... And thats all. It can't switch to a valid 28,2 channel I suppose...
                      Anyone can help with solution?
                      • trampa
                        when selecting the plugin it goes "loading" and comes back to the plugin list
                        doing something wrong?
                        • aldi99
                          I?ll try install on gemini4.7
                          ist there any automated download in BluePeer available (download server for pkg?)
                          • tvbors
                            • Jun 2011
                            • 20
                            #28
                            woohoo thanks finally got it working
                            • micflair
                              • 275
                              #29
                              Hmm today Crossepg + Rytec seems to be down for me today.. grr
                              • stojko33
                                • Dec 2011
                                nice i hope it works
