Original DM800HDd
  • skydive80
    • May 2010
    • 168
    Original DM800HDd
    Hi guys,
    looking for a little help please if pos, I digged out my original DM800HD and decided to flash it with a cloned image thinking it will be ok, I now got the dreaded NO CA ERROR, I have had this in the past and used dreamup to fix the error however this time every image I put on this box it tells me wrong image or old image, I have tried changing the boot loader and putting on a original dreambox image and still the same problem, I have read I need to put the original Gemini image on the box (factory one) but I can't find a copy anywhere.
    also tried the dreambox tool but no luck.
    any suggestions guys would be much greatfull.
    many thanks,
  • digicon
    • 8261
    There are plenty of gemeini Images in the download section perhaps work your way backwards from the end posts to find a suitable one, Dreamup 1336 has never failed me yet on the 'No CA Error' also should be in the downloads
    • skydive80
      • May 2010
      • 168
      Thanks bud, found an image from dreambox downloads and used dreamup you suggested and now working..... a thanks again
      • digicon
        • 8261
        No Problem just glad you managed to get it sorted
        Well done
        • toysoft
          • 752
          Use JapharFlasher,
          TS
          MEGA :
          PHP Code:
          https://mega.nz/#!7c4RDSBR!tHuDF-84p1L_VYcCLK2FMiZauIQTBL9uQievaNpLq4U
