DM8000HD : OpenPli 4.0 IPTV MastaG Japhar Team 1300 FREE IPTV Ch GStreamer 1.9.0.1b
  • toysoft
    • 752
    OpenPli 4.0 IPTV by MastaG / Japhar Team with 1300 FREE IPTV Channels and with GStreamer 1.9.0.1b (May 6th 2016)
    Changes:
    - Latest gstreamer 1.9.0.1 snapshot based on recipes from christophecvr:
    * Proper fix for HLS segfault on stop
    * Re-enable the rtmp seeking and potential segfault fix
    * gstreamer1.0-libav is now built against system ffmpeg instead (this differs from chris recipes) *
    * dvbmediasink patches for Vu Solo 4K, hd1265 and hd1500 from oe-alliance
    - FFMpeg updated to 3.0.2 and is now installed by default *
    - Backports to enigma2 for sh4 (mainly servicemp3.cpp related)
    - Fix EPG on sh4 receivers
    - exteplayer3 is now installed by default, thank you mx3L and samsamsam *
    - gstplayer is now installed by default, thank you mx3L and samsamsam
    - Mediatomb is now in the feeds
    - MediaPlayer2 is now installed by default, thank you mx3L
    - SubsSupport (for MediaPlayer2) is now installed by default, thank you mx3L
    - No more russian tuxtxt
    - Its now possible to set the debug level again in the UI-settings menu, thank you christophecvr
    - Latest enigma2 changes, thank you OpenPLi
    - latest openpli-oe-core changes, thank you OpenPLi
    - ServiceApp, thank you mx3L !!!
    Known issues:
    - On spark7162 (and 7111 probably as well) fragmented streams such as hls (m3u8) will skip and freeze a lot.
    This happened sometime after the official Gstreamer 1.8.0 release and I didnt found the cause yet.
    It is not related to the dvbmediasink since it doesnt happen on mips receivers and the code in the dvbmediasink didnt change.
    Configure your streams to play with exteplayer3 instead, read below.
    - * On the 64MB Dreambox models (DM800HD, DM800Se and DM500HD) there is not enough space to ship ffmpeg.
    This means that exteplayer3 and gstreamer1.0-libav arent installed as well because they depend on ffmpeg.
    See my attached guide to copy over the root filesystem to a storage device.
    - Some Dreambox remotes may behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    Thanks for the hard work from mx3L and samsamsam you can now play your IPTV streams with exteplayer3 or gstplayer instead of the default dvbmediasink.
    Especially using exteplayer3 will give much better performance on playing HLS streams compared to gstreamer + dvbmediasink.
    For example, playing DJING underground 720p never worked very well on my DM800HD and now it does
    DM8000HD+ Japhar : https://mega.nz/#!oFEAxaCa!y2YvAL-40...kQ8VNfKUuiHW88
  • toysoft
    • 752
    VU+/DM Japhar OpenPLi 4.0 IPTV image from MastaG, 1300 Free IPTV Channels
    Here s a new batch of images based on OpenPLi 4 with many contributions from various openpli.org forum members and some bits taken from oe-alliance.
    So this is basically a tribute to them
    It took me a while since I was very short on time and I had to re-install my build-rig, move to a new feed-server etc...
    SO DUE TO A NEW FEED-SERVER ONLINE UPDATE FROM PREVIOUS IMAGES IS NOT POSSIBLE!
    DON T TRY TO CHANGE THE URL IN THESE OLD IMAGES SINCE THERE S BEEN TOO MANY CHANGES WHICH WILL BREAK THINGS!
    PLEASE FLASH A CLEAN IMAGE INSTEAD!
    So here s whats up:
    - Brand new bootlogo thanks to .:MarcinO:.
    - OpenPLi enigma2 rev: 4bf2f1e45593065f9e2b4563f30463487b727c94
    - OpenPLi oe-core rev: d76cfe6a39c6613ac77578840b214f0f1e748a39
    - Taapat s Fulan enigma2 rev: 2a984c500f5b2ea657f68742b7dc4e47f5586483
    - New receivers supported:
    * osmini
    * osminiplus
    * spycat
    * spycatmini
    * et7000mini
    * xpeed lx
    * xpeed lx pro
    - New feed server located in Europe thanks to the Japhar team!
    - New Japhar IPTV list
    - No more use of UPX compression on ARM platform (should fix the Vu+ Solo 4K build)
    - Latest gstreamer 1.9 revision from master branch
    - FFmpeg 3.0.2 with extra options enabled (based on oe-e recipe)
    - Kodi 16.1 for Vu+ Solo 2, Solo Se, Duo 2, and Solo 4K (thanks to mx3L for his bsp + recipes)
    - More wifi drivers (mt7601, rt7777 etc..) taken from oe-alliance
    - Slightly newer v4l modules for kernel 2.6.18 (dm800)
    - New version of mx3L s serviceapp now supports EPG and embedded subtitles
    - New version of exteplayer3
    - Flash extender PPanel for dm800, dm800se and dm500hd (* Please read below)
    - Many other changes I forgot to mention...
    Known issues:
    This happened sometime after the official Gstreamer 1.8.0 release and I didn t found the cause yet.
    It is not related to the dvbmediasink since it doesn t happen on mips receivers and the code in the dvbmediasink didn t change.
    Flash extender for DM800, DM800Se and DM500HD:
    Since these receiver only feature 64MB of internal flash space, I ve been unable to ship all packages.
    ffmpeg, exteplayer3, gst1.0-libav, mediaplayer2, iptv player, subssupport etc.. are missing due to insufficient space.
    That s why I ve created a simple PPanel script for moving the entire internal flash to an external storage device such as internal hdd or usb disk.
    The PPanel will also install all the missing packages for you.
    So you can have all the bells and whistles like the other receivers
    However please note that:
    - It will format your storage device thus deleting everything.
    - It s not compatible with other flash-extenders such as barry alen, multiboot etc...
    - You ll need a working internet connection when running the PPanel or else it cannot install the missing packages.
    - You need to patient! As the script runs you ll only see a black screen which an take up to 15 minutes depending on the size/speed of your storage device and your internet connection.
    You can find it under Blue Panel -> PPanels
    ServiceApp and exteplayer3:
    In a nutshell here s how it works.
    In your /etc/enigma2/ directory you have your channel bouquets with the .tv and .radio extensions.
    Inside these files there s this for example:
    #SERVICE 4097:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
    #DESCRIPTION DJING Underground (CDN)
    By default this will play with the gstreamer dvbmediasink (which is currently broken for sh4).
    If you like to play your stream with exteplayer3 instead you should change the 4097 to 5002, like this:
    #SERVICE 5002:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
    You can also change it to play with gstplayer using 5001:
    #SERVICE 5001:0:0:0:0:0:0:0:0:0:http%3a//cdn.djing.com/tv/u-05.m3u8JING Underground (CDN)
    So it s like this:
    4097 = default player, which is the dvbmediasink if serviceapp is not enabled
    5001 = gstplayer
    5002 = exteplayer3
    Now let s say you d like to convert your entire bouquet to play with exteplayer3, simply login to your receiver with telnet/ssh (use PuTTY for Windows).
    And issue to the following commands:
    First stop enigma2:
    init 4
    Then change your bouquet to make all streams play with exteplayer3, lets say userbouquet.favourites.tv:
    cd /etc/enigma2
    sed -i s/^#SERVICE 4097/#SERVICE 5002/g userbouquet.favourites.tv
    Then restart enigma2:
    init 3
    That s it !
    You can also make exteplayer3 the default backend for playing back everything.
    Go to Menu -> Plugins -> ServiceApp and set exteplayer3 as default.
    Keep in mind that with exteplayer3 or gstplayer as default backend you will not have support for external subtitles yet (.srt for example).
    That s why I ve added MediaPlayer2 and SubsSupport from mx3L.
    Please thank mx3L for the hard work he put into this
    - Japhar
    DM8000HD : https://mega.nz/#!eFhUmJYZ!SuirJs7XP...PC4zc8s_eGNfLE
