Hi
I used the Universal Dreamup program and flash erased and added nabilo image, and am able to get FTA channels of 28.2 East. I have tried to use the Satfind option on set up menu to move the motor to 19.2 east or any other satellite but see the motor looks to be moving dish to 6 to 8 degrees west and get no signal (as far west as motor will go ?)
I have managed to set up 5w and 1w by using technomate to move to sat position and then doing scan as if fixed dish and save position, then change to multi satellite setting and can find saved satellites fine. I though I could do manual search like on technomate 1w and look for bbc world and move dish till fine, but there are no channels programmed on dream box ?.
Is there and easier way to set up? I dare say can do it all manually given time?.
Can you get sub titles using nabilo image?
And after setting up satellites and fav channels can all this info be save? Just in case have any problems ?.
