DM 500s have a proble with starting
  • ahmed2003
    • Sep 2016
    • 7
    DM500s have a problem not starting on logo only front Green light
    blank display
    power supply changing but problem not solved
    dreamup using new pli gemini image
    but response
    please help me all
  • plasterer
    • 1631
    Try taking the top off the box and pushing the ribbons back on securley.............Paul
    PAUL
      Buy a new box minge bag times have moved on
      • ahmed2003
        • Sep 2016
        • 7
        Thank you guys for reply
        please solved my problem
        any idea have
        • 4nubis
          • Jun 2016
          • 182
          Did you open and watch inside the Box, if is all ok like electrolytic capacitor?
          • ahmed2003
            • Sep 2016
            • 7
            please send me electrolytic capacitor pic i will try
            • ahmed2003
              • Sep 2016
              • 7
              sir receiver is on
              but no display
              receiver front light Green on
              power supply adapter is ok
              • 4nubis
                • Jun 2016
                • 182
                Mate the 500s doesnt has a display...only LEDs...so all fine
                • ahmed2003
                  • Sep 2016
                  • 7
                  i thing problem have a 470uf 25v capacitor
                  can i change capacitor
                  Maybe the problem's solution
                  by mistake . Laptop Charger Was invested
                  • 4nubis
                    • Jun 2016
                    • 182
                    For sure you can change.
                    • ahmed2003
                      • Sep 2016
                      • 7
                      thank you so much
                      sir 4nubis
                      i will try
                      • ahmed2003
                        • Sep 2016
                        • 7
                        my problem is not solved all member's please help me
                        how can i do
                        • psats
                          • 823
                          try this way.
                          How Do I Use Dreamup? If, for any reason, your box won't boot, you will have to use Dreamup to flash an image instead of Flash Wizard Pro or any other method. You won't be able to connect via ethernet so no ip address is required. It may be that the process simply hung up during flashing or you accidentally pulled the plug
                          • 4nubis
                            • Jun 2016
                            • 182
                            Success with new image?
