URGENT HELP NEEDED dm800hd no ca found
  • gordonsmthsg
    • May 2013
    • 4
    DM800 URGENT HELP NEEDED dm800hd no ca found
    Hi all if someone could help me out with my "no ca found" issue on my DM800hd pvr i would be eternally great full. basically whats happened is, i came home about a week ago and i was informed by my wife the electric had gone off during the day and when she has switched it back on the dreambox wouldnt work (stuck on the boot screen) ok i thought needs the image reflashing, so rebooted the box with the stop button in and logged in via the web. stupidl i though hey why not try a new image and jumped on here and grabbed an open PLI one went through the motions and boom i get the dreaded "No CA Found" error now
    again i thought ok no big deal i'll get the RS232 null modem lead out (all be it a null to usb one ) and sort this out, low and behold couldnt get windows 10 to get the correct driver blar blar blar any who i went to work grabbed an old XP desktop with a proper serial port on the back and new null modem lead happy days i thought i'll get back download dream up and connect to the box and flash away OH NO YOU WONT
    i just can no for the life of me get this box to connect to the computer, i have tried the enforcer tool and that gives me an error that the file is too big when its only 147kb or something really small
    if someone could help me through this i will be forever great full
  • toysoft
    • 752
    Which image did you installed ? Probably a quick fix would be to replace the old sim by a Japhar Sim that is capable of running all clone images from Ferrari, Sim2 2.01, Sim2 2.10 and Japhar. Just putting it instead of the old one could get your box working again without the headhach of the DeamUp (or JapharFlasher that is capable of restoring any DM box).
    TS
    • toysoft
      • 752
      I sent you a PM as requested with details,
      TS
      • mini
        • 602
        no CA fix in download section 》》 http://www.digital-kaos.co.uk/forums...o=file&id=2684
        if that doesnt work, you may have to jtag it... only way.
        connect dream up and connect the RX TX Grnd lead. (if on box you have a com port connect (from left to right) 2nd connevtion to RX, 3RD connevtion to TX, do not connect 5TH to ground. press connect on dreamup then switch box on, if it says dmxxxx then only option is jtag. ut not 100% sure. just double check.
