DM800HD PVR IP problem !
  • fahimjan
    • Aug 2011
    • 56
    Dear Friends,
    I can not connect my DM 800 to the computer via IP address, Is there any guidance or any solution ?
    But, it can be connected to the network via that IP address and run the xxxxx.
  • fahimjan
    • Aug 2011
    • 56
    I think, I need to install Web interface with DCC, but, how ???
    • toysoft
      • 752
      Flash a proper new image, as all these things should work. So press the frontpanel button when you turn on the box until you see on the LCD the IP Address, then flash an image that is compatible with your sim in the box, and all will work again.
      TS
      • fahimjan
        • Aug 2011
        • 56
        I did, but, still cant get connection with browser to flash a new image !!
        TS
        • cunny
          • 4915
          Have you checked the IP address is correct? Power off, back on holding the power button until 'stop' appears. Then try connecting to the ip address displayed on LCD
          • fahimjan
            • Aug 2011
            • 56
            Yeah, I know the IP address of the box and i set it manually with no DHCP !!
            Its all about the Webinterface , I think, I removed it !!
            • cunny
              • 4915
              Then check in the pluggins page. If nto there either download it again or flash a new image
              • toysoft
                • 752
                The Webinterface in the image has NOTHING to do with the Flashing of the box.
                And to successfully flash the box YOU MUST set both cables, RJ45 + RS232 (REAL), and use a DHCP or something similar (Fixed IP set by your router), as the ROUTEUR must give an IP Address to your box and it must show up on the LCD.
                Only then you will be able to flash your box properly,
                TS
                • kaz84
                  • Jul 2016
                  • 5
                  If you have a doubt on the web interface you can try an FTP client like filezilla and connect to the box only using ftp protocole.
