no services no bouquets
  • gorshan
    • 4
    i have set the dreambox to factory default. when i accessed it thru dreamboxedit,the files from the dreambox shows no services and bouquet. what should i do? how do i add/restore services and bouquet?
    <--gorshan added 2 Minutes and 9 Seconds later...-->
    is dreambox only fta and can encrytpted channel be watched only thru card sharing?
  • robbieb43
    • 16
    Hi Gorshan
    If I understand correctly you haver just flashed your box with a new image? if so it is normal that you will see no channels. You either need to upload the channels that you previously saved (using the "open" option in dbedit or dreamset) and write them to the box, or do a channel scan.
    Suggest you google for cardshare dreambox on the other bit.
    R
