Dreambox DM500-S - Dreambox Edit connection
  • depth71
    • Sep 2009
    Hi,
    My openbox stopped working and ive ordered a replacement ubt in the meantime i've found my old Dreamboc DM500-s to use in the meantime.
    It is flashed a ive used it before but i'm trying to connect to it using Dreambox Edit but it says it cannot find the dreambox on the network.
    The IP address is correct.
    I've changed the ethernet cable just to make sure it isnt that.
    Also are there still channel lists available for this box?
    Lastly, how do i put the c line on the box?
    If i remember correctly its going to be different to the Openbox one.
    Any help gratefully received.
  • plasterer
    • 1631
    Good first post mate . You took a long run up with it ..................Paul
    If your Happy with the Help push the Thanx button
    PAUL
