where is ccam.prio file on pli jade 3
This topic is closed.
  • PAULOG
    • 37
    hi guys trying to add a line into the ccam.prio but cant find it , found the ccam.config but no ccam.prio any help greatly recieved
    Paul
  • firestorm
    • 1550
    some new enigma2 images dont use that file any more
    • PAULOG
      • 37
      should i go back to and old image then, i was advised to add in to watch a sports channel
      • firestorm
        • 1550
        thats a bit ott have you tryed to use say captian or vanibals setting
        • PAULOG
          • 37
          how do i do that, thanks
          • PAULOG
            • 37
            is that when u download channel settings
            • firestorm
              • 1550
              you can download them of the net just goole them then unzip them into a folder then move them to your box with dreambox edit or the easy way is to go to the downloads section on your pli image and load them from there
              • PAULOG
                • 37
                hi i downloaded a few different channel setting but still no luck with what is best image thatn has cccam.prio on on it thanks
                • Curious123
                  • 2591
                  None of the images will have Cccam.prio loaded so as firestorm says you need to search the net for the file.
                  • tomthebomb1968
                    • 56
                    What cards are you wanting to give priority to.
                    • vavilon
                      • Jun 2009
                      sky italy...sky uk.........thank you..
                      • opsmonkey
                        • 5379
                        this is turning into a CS help thread..
                        • aftermath
                          • 4345
                          Its against the Forum rules to post topics on card sharing or similar,.
