If you want to make up a null modem cable to flash your box, the following are the pin outs that worked for me:
Pin 1 - Pin 4
Pin 2 - Pin 3
Pin 3 - Pin 2
Pin 4 - Pin 1 and Pin 6
Pin 5 - Pin 5
Pin 6 - Pin 4
Pin 7 - Pin 8
Pin 8 - Pin 7
Pin 9 - Not used
If you have a cable and don't know if it's a null modem cable, just test the pins as per the connections above with a metre and you will then know.
Hope this helps out someone!!
Pin 1 - Pin 4
Pin 2 - Pin 3
Pin 3 - Pin 2
Pin 5 - Pin 5
Pin 6 - Pin 4
Pin 7 - Pin 8
Pin 8 - Pin 7
Pin 9 - Not used
