No,
On SatFind, you first put the satellite you a trying to find, then move your dish, when you hit the satellite it will show a high signal rate and no BNR.
No,
if you are having trouble with this mate i dont think this box is best for you.. you should have gone with something a bit more start up user friendly..
at the bottom of the satfind it says:
Satellite & Transponder
Just change the satellite option with the remote control until it's on the satellite you want
put this in mate see if this help you out you might have to reboot you box to see it unzip and ftp it to var/tuxbox the hard works dun for you just send the file m8 will all sof at the bottom not knowing anything but once you got the hang of it its easy donot like people put you off by just saying use the seach button because most of them are to affaid to ask for help
Its a bit like when you are kid and you want to learn to ride a bike. You see eveyone riding round on a bike but you just can't seem to get the hang of it no matter how hard you try and that just makes you feel even more determined.I would say that if you are messing around with the S*y dish then this is probably hampering your chances of getting something on your box purely because they are too small and fixed.If you had left the dish at where it was you would have got all the FTA stuff and then you should have concentrated on getting the rest in which in principle would have taught you a little bit about c/s and then you should have moved on to the next set of sats.
sky dish will pick up 28/19/13 easy they are alll stong birds in the sky
I got my 1m sat dish about 12 months and I remember trying to align it to pick something up in fact anything up and got nowehere for 2 weeks so I can fully understand and sympathise with someone trying to get reception on a 60cm dish.
My better half's been with me long enough to realise that once I get a bee in my bonnet about doing something everything else just fades in the the distance and it is easier to reduce the pain by joining me. Here is picture of my set up and you can see why it took two weeks to align.
