ok finally got my image on, is there anyway i can check tos eeif it is on?? also i want to watch channels on there, do i have to set up an internet connection or something?
internt dreambox
Tags: None
The DB must have internet connection, either wired by en Ethernet cable to the ADSL router or use mouse WiFi (avaialble from Linux sat) if no LAN connection is possible.
You can check the DB have ip address , on a Nabilost image yellow button - blue button and run ipconfig script. On other images just browse the menu you will find something about checking the ip address so just ping the DB box from your PC and it should reply. -
You will need an internet connection if you are thinking C/S. Why not check out the guide below as it covers most of the basic setup.
ok so i have the image on it, pli jade. any ideas how i can connect it to the net, dreambox 600 downstairs, upstraits internetComment
