Cam, image, OS somehow confused!
  • bluebiker21
    • Aug 2008
    • 7
    can anyone clarify the difference between CAM and image?
    Does image refer to the OS, ie linux OS?
    I know there are many CAMs that can be loaded on one box, but what exactly is a CAM?
    and what's a server? Is it an internet hosted server that the dreambox contacts to get key updates all the time?
    And also what s the Gemini project? is it a server?
    Thanks for the clarifications
    <--bluebiker21 added 1 Minutes and 35 Seconds later...-->
    The Emu, it s the CAM?
    <--bluebiker21 added 0 Minutes and 34 Seconds later...-->
    I love this forum!
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Sounds like you've found some stuff out on your own.
    The image is simply another name for the firmware. Linux is the OS that's used to create the firmware and so its Linux based.
    A cam (conditional access module) is really a slot thingy that you would use to slot your subscribed card into then put that into your receiver.
    The emu is short for emulator but the actual term should be Softcam because its a cam in software form, i.e. evocamd, mgcamd, etc.
    There are various groups that develop images/firmware, The Gemini Project are just one of those groups. Others include PLi, RuDream, Nabilo, CLi, Digital Kaos
    There is 2 main types of images, neutrino and enigma (both linux based). Most of the firmware creators use enigma but RuDream use neutrino.
    Hope that clears a few things up.
    • bluebiker21
      • Aug 2008
      • 7
      How to load new image?
      cant thank you enough for your quick reply, it's such a relief!!
      I have downloaded the latest image you posted and sent it to the dreambox using DreamUPLAN. The image shows as flashimg.img under /tmp.
      How can I run it on my box?
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        This guide should tell you all you need to know.
        Although you will need to either rename the file to backup.img or adjust the command to have flashimg.img.
        • bluebiker21
          • Aug 2008
          • 7
          thanks again!
          I yused the commands u mentioned and the image is intalled.
          During initial setup (on first booting of the dreambox), I set up only two satellites, how can I set more now that the box is running?
          Also, where can I get CAMs in this image?
          • krazylegz
            • 2834
            you can select satellites to scan by usng the remote and going to sevice searc section, emu's can usually be found via the addon server if connected to the net, usually blue button, nabilosats is yellow x2
            PS3= krazylegz120282
            • bluebiker21
              • Aug 2008
              • 7
              I was able to find the addon server with remote. I managed to add few CAMs manually after tftping their tar.gz files to /tmp. However when I go the EMU manager, I find only Evocamd 2.12 although I did install other CAMs.
              PS: When I try to install from DK addon server, I get the same message for all CAMs: An error occured during http actions. (Percent in use 93%)
              One more thing, I couldn't find satellites to scan using remote, can you please elaborate a bit more.
              Thanks a LOT!
              • krazylegz
                • 2834
                the reason some emu's wont be there is because although you downloaded a tar.gz a emu is different for each image, so the ones you might have were no made up for the image you have, you need to download them from the server, you might need to re-flash image as when you've been trying to ftp emu's its quite possible that you might have used up precious space in /var folder so there mightn't be enough space for you to download any now.
                satellies is something along the lines of
                menu--setup--expert setup--service serching
                • bluebiker21
                  • Aug 2008
                  • 7
                  Loading CAMs
                  I re-flashed the image on my dreambox in order to win more space in /var. All I was able to install is Scam3.28, I got the same error (An error occured during http actions) for other CAMs. Keep in mind that I had to remove Evocam in order for Scam to work.
                  How can I get more space on /var, is there a way?
                  • Fergal
                    • Aug 2008
                    • 1007
                    Why do you need more space you only need 1 camd try cccamd
                    • bluebiker21
                      • Aug 2008
                      • 7
                      I reflashed, removed evocam and tried cccamd 2.08, again the same error. (I had Percent in use 29%). Any clue? Thanks
                      • Devilfish
                        Administrator
                        • Feb 2008
                        • 7872
                        I'll have a look at that addon tonight when I get in from work to make sure it's downloading ok.
                        Also moved this thread to the satellite section.
                        • newman9
                          • Mar 2009
                          Thanks for clarification. I love this board...
